| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| Off-Road Rangers Under Construction Share your off-road Ranger projects here so we can follow the progress. |
Thread Tools | Display Modes |
#61 | ||
Year: 1994/2004
Make: Ford
Model: Ranger XL/F250 XL
Engine: 2.3L/5.4L
Class: 4x4
Used For: DD and Mild Wheeling
Rep Power: 15 ![]() ![]() iTrader: (2)
Quote:
Quote:
Don't worry about the crossmember. Get to it when you get to it. I'll bug you more when I really need it. I have plenty to keep me occupied at the moment. Is the new project the F350 you bought? What are you doing to it?
__________________
"Light beer is just wasting your time..." -My grandmaProject Little Green Turd F250 Build Last edited by wizkid00104; 07-12-2012 at 06:28 AM. |
Tweet
#62 |
Year: 97,79,00,72,71
Make: Ford
Model: Ranger, F250, F350, Mustang, Bronco
Engine: 3.0, 460, 7.3psd, 351c, 351w
Class: little bit of everything
Used For: waste all my money
Rep Power: 11 ![]() iTrader: (68)
Is the new project the F350 you bought? What are you doing to it?[/QUOTE]
Thats it. I'm painting the frame and cab/bed underside. gonna prob repaint the whole truck eventually. I bought all the badges, bumper, grile, lights, etc to convert to 06 style. Its runs great has about 3k in aftermarket goodies on it.
__________________
97 Ranger 3.0 5spd 1354m disc 8.8 00 F350 Dually Crewcab 4x4 7.3 6spd 79 F250 501BBF,4spd, d60, 10.25 38s 72 Mustang Mach1 351C, 4spd 71 Bronco d60, 14bt, 351efi, 4spd,203/205, 44s beadlocks plus lots more |
Tweet
#63 | |
Year: 1994/2004
Make: Ford
Engine: 2.3L/5.4L
Class: 4x4
Quote:
Pictures? I want to put the 05 Harley Lights on mine and just replace the broken stock grill. I may be able to use your leftover grill if its in good shape. Also want to add factory fogs.
__________________
"Light beer is just wasting your time..." -My grandmaProject Little Green Turd F250 Build |
Tweet
#64 |
Year: 1994/2004
Make: Ford
Engine: 2.3L/5.4L
Class: 4x4
Well, I finally got the front axle out!
![]() Started at 10 pm Friday night and worked till 5 am. Finished pulling the axle Saturday afternoon. Here is the progress: Fuel for productivity... West Newton Pizza House (the best pizza ever) and a cold Pabst Blue Ribbon (great cheap beer) ![]() First Coil Out... I had 4.0L explorer coils on here. This is them next to the new Duff coils. Lower retaining hardware is laid out. ![]() Here is the removal process. I needed an external coil spring compressor to help get the nut lined so I did not need a universal joint. I applied pressure to the bottom of the axle housing with a floor jack. This allow me to get a 27mm socket on the drivers side and 1 1/8" on the passengers side (thanks to rust and rot) to remove the nuts. To get them started, I had to use a 4' breaker bar extension. ![]() ![]() ![]() ![]() Some of the toys in the garage. My F250 in the background, Joey's 2005 Honda 400EX, and Joey's dad's 2007 Harley Davidson Electra Glide Classic. ![]() To remove the studs to separate the radius arms is warmed the studs with a small propane torch and then cooled them in water to loosen up the loctite and rust that has been building on them for 18 years. I used a 1 1/8" ratcheting combination wrench with a second wrench as a cheater. The deepwell socket I had would not clear the stud, so these came out but hand. I used the same setup to loosen the radius arm nuts as well. But I was able use an impact wrench once I broke them loose. ![]() ![]() As it sat 5am Saturday morning...
__________________
Tweet
#65 |
Year: 1994/2004
Make: Ford
Engine: 2.3L/5.4L
Class: 4x4
Saturday around 2 pm work resumed...
First Radius arm off ![]() ![]() Front out... Passenger side needed a B.F.H. to get the radius arm off. ![]() ![]() ![]() I separated the tie rod ends and the slip yoke to make for easier movement. I removed the sway bar brackets because I see no use for them. I just have to beat the axle pivot bushings out so I can get the new James Diff ones in. Given the past track record with bushings... that should be a real fun time ![]() ![]() Nearly empty frame... Joey torched a few rivets off. Still working on removing riveted brackets. But once they are all off, I will clean stuff up and hit the frame with some rustoleum so the new lift can go on! Here are two comparison shots. This is the old and new drivers side beam drop bracket. The difference in quality between one manufactured of 0.250" plate and welded and a factory bent one is staggering ![]() ![]() ![]() And the big one... the driver's side stock radius arm to the Duff radius arm. I don't think much comment is needed for this one. See for yourself... ![]() That heim joint has a 1" bolt in it for a size reference. ![]() Ended the weekend by going out on the quad for a ride. It always nice to get away and clear your mind. ![]() More to come... And Happy Birthday to my dad!
__________________
"Light beer is just wasting your time..." -My grandmaProject Little Green Turd F250 Build Last edited by wizkid00104; 07-16-2012 at 04:49 PM. |
Tweet
#66 |
Premium Member
Year: 1993
Make: Ford
Model: Ranger
Engine: 4.0L
Class: 4x4
Used For: Weekend Warrior
Rep Power: 21 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (8)
Lookin good man! I would gusset that drop bracket tho, just to be safe. I cant believe I missed this build, TTB ftw!!
Tweet
#67 | |
Year: 1994/2004
Make: Ford
Engine: 2.3L/5.4L
Class: 4x4
Quote:
Where would you gusset them? The passengers side already has an additional mount to the frame. They have a good quality fell to them, unlike the stock ones I can believe it, there are too may builds on here to keep track of!
__________________
Tweet
#69 | |
Year: 1994/2004
Make: Ford
Engine: 2.3L/5.4L
Class: 4x4
Quote:
The only reason I will hesitate to remove Duff's nice powdercoat is because the brace they added on the side will mount forward onto the frame adding the front to rear flex support. While it is not on the tabs you mention, I think it will support the bracket as a whole. I appreciate you bringing it to my attention though, I overlooked that in a heart beat. To support this, I have yet to hear any complaints of Duff's brackets and I am more than willing to try them in stock form. I have found tons of odds and ends to change as I go, but my goal now is to get this thing back on the road. I love driving it and I am getting anxious
__________________
Tweet
#71 | |
Motorboater (.Y.)
Year: 1988, 2000
Make: Ford
Model: Bronco II (Eddie Bauer), Explorer
Engine: 2.9L, 4.0L
Class: 4x4, 2WD
Used For: Annoying the old ball and chain.
Rep Power: 48 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (6)
honestly, i dont think you'll need to gusset a duff bracket. i cant recall of ever heaing of one breaking. the duff brackets are probably more stout than the newer skyjacker brackets. they have that piece that mounts to the frame above/in front of the bracket. i doubt you'll have problems unless they start rusting, but that should be a while
__________________
BUILD THREAD<<<<<<<<<<<<< The Tikki Torch Build Thread 1988 Bronco II 4x4 2.9, FM146, 1350M, Disc 8.8, D30 SAS, 3.73's, 31's (for now) 2000 Explorer 4.0 2WD DD Everything I need to know about Islam, I learned on 9/11. The hardest part about a zombie apocalypse will be pretending I'm not excited. Quote:
Tweet
#72 | |
Year: 1994/2004
Make: Ford
Engine: 2.3L/5.4L
Class: 4x4
The F250 tends to hurt my wallet, or what's left of it
Quote:
__________________
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
