Serving Ford Ranger, Bronco II, Explorer & Mazda B-Series Owners Since 1999
Home Forums Info - Technical Info - Other TRS News Photo Galleries Shirts & Decals Parts Store Classifieds
Go Back   The Ranger Station Forums > Axles, Brakes, Wheels & Tires > Brakes
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 07-11-2012, 09:02 PM   #1
Dave
Junior Member
Year: 1992
Make: Ford
Model: Ranger
Engine: 3L
Class: 2wd
Used For: getting from point A to point B
Dave is on a distinguished road
Default Brake Bleeding Issues
Hey, Guys. I'm having problems with the brakes on my 1993 Ranger (2wd, 3L, automatic, rear ABS). The brake line that goes from the ABS valve to the "T" fitting on the rear axle housing rusted out and developed a very small leak. I drove the truck home with no issues and barely any brake fluid loss. The brake pedal didn't even feel bad. Today I replaced the brake line. I tried bleeding the brakes and I am getting no fluid at all from the rear brakes. I've done a lot of brake repairs over the years and bled lots of brakes....never a problem before. The brake pedal is hard like there is nothing wrong. I think the ABS valve is the problem but I know nothing about it. Is there something on the ABS valve I need to reset or something? Ironically this is not the first time I've had to bled the brakes on this truck and I've never had a problem before. After forming the new line, I blew the line out with compressed air to make sure there was no junk in it. Please, somebody help me. Thanks.
Dave
Dave is offline   Reply With Quote
Old 07-12-2012, 09:10 AM   #2
tx3nc
Year: 1993
Make: Ford
Model: Ranger
Engine: 3.0L V6
Class: 2WD Street
tx3nc is on a distinguished road
Default
I am not aware of anything on the hydraulic valve that needs to or can be reset. The valve has 2 solenoids in it. One to block the brake pressure to the rear brakes, the other bleeds off pressure into a reservoir. The brain box controlls the two solenoids to modulate the pressure to the rear brakes to prevent lockup. One of the solenoids might have stuck closed. I would either pull the valve and replace it or try to clean it. I don't have a cleaning procedure for it but I have seen some people have done it with success. You might be able to find the procedure with a web search.
tx3nc is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2012 / 959 Media LLC / All Rights Reserved
[Legal Notices]   [Advertising/Vendors]
Also check out SSP Central for Special Service & Non-Traditional Police & Fire Vehicles
