Serving 1984-1990 Ford Bronco II Owners & Enthusiasts
Home Library Bronco II's For Sale Bronco II Gallery B2C Shirts & Decals The Ranger Station
Go Back   The Ranger Station Forums > Truck Discussions > Bronco II & Explorer Specific
Notices
Bronco II & Explorer Specific Also check out our Bronco II section at the BroncoIICorral
Post New Thread Reply
Thread Tools Display Modes
Old 06-21-2012, 12:06 PM   #1
19turner73
19turner73's Avatar
Year: 1989
Make: Ford
Model: Bronco II
Engine: 4.0L
Class: 2wd
Used For: Daily Driver
19turner73 is on a distinguished road
Default '89 B2 rear end
Hey guys! I have a few questions concerning a 2.9l to 4.0l swap. The motor swap is complete and running smooth, but I am having vibration issues from the rear. Obviously we're looking at bearings and raceways....but.....I am still using the original pumpkin. Should I check out the bearings and replace them all, or swap the rear end. Has anyone done the rear end swap? What would be a good donor? Replacing the bearings is fine, but I don't want to replace them if the rear end can't take the torque of the 4.0l.
19turner73 is offline   Reply With Quote
Old 06-21-2012, 12:22 PM   #2
Shran's Avatar
Shran will become famous soon enough
Default
You sure it is the axle and not a u-joint or the carrier bearing?
The 7.5 axle is decently strong, I'd not focus on replacing it if you don't have to. Otherwise a Ranger 8.8 with drum breaks is the next best option to swap in.
__________________
1986 Ranger XL 4x4, 302, NP435/205, HP D44, RCV shafts, 8.8 Lock-rite/lsd, 4.10 gears, 35" BFG M/T --- Build Thread
1996 Ranger XLT 4x2, 2.3, M5OD
1986 F150 4x2 302/T18
1985 F250 4x4 460/T19
Shran is offline   Reply With Quote
Old 06-21-2012, 12:24 PM   #3
Tracked and Locked
Asteroids Champion
adsm08's Avatar
Year: 1987
Make: Ford
Model: Ranger XLT
Engine: 2.9 High Performance
Class: 4x4
Used For: Elevenses
adsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond repute
Send a message via AIM to adsm08
Default
What he said. The 7.5 is not the preferred axle behind a 4.0, but in reality is not any weaker than the 8.8 that came in the Ranger for years and years. I think the preference for the 28-spline 8.8 by Ford was mostly for the larger brakes.
__________________
Project: Hillbilly Deluxe
Project: Amazing Grace
Project: 12-Volt Sandwich
Quote:
Originally Posted by Raj
What you need is cheat codes, motor skills, and a magic genie who grants wishes to little boys who suck at Mario Kart
Quote:
Originally Posted by John Adams
Our Constitution was made only for a moral and religious people. It is wholly inadequate to the government of any other.
HELP REPEAL OBAMACARE
Looking for 95-98 manual trans pedal bracket. Conducting an experiment for the betterment of all Ranger-kind.
adsm08 is offline   Reply With Quote
Old 06-21-2012, 12:51 PM   #4
country0001
gravel in my travel
country0001's Avatar
Year: 1990,92
Make: Ford,Ford
Model: B2,F150
Engine: 4.0,5.0
Class: 4x4, 4x4
Used For: tearin up the gravel roads
country0001 has a spectacular aura aboutcountry0001 has a spectacular aura about
Default
I'd definitely check the driveshaft, especially if its a CV style shaft. I've been running a 7.5 behind my 4.0 for 2 years. I haven't had any problems out of it.
More info will probably be needed
__________________
Quote:
Originally Posted by MountainMike View Post
"Quietly the BroncII waits for the prey to walk past, the Ranger will have to wait its turn."
BUILD THREAD http://www.therangerstation.com/foru....php?p=767381#
country0001 is offline   Reply With Quote
Old 06-21-2012, 02:25 PM   #5
Shran's Avatar
Default
My bad, I was thinking Ranger driveshaft, thus the carrier bearing reference. Ignore that.
There is a good chance you have the CV style driveshaft, and there is an even better chance that if you do, it's worn out.
__________________
Old 06-22-2012, 10:08 AM   #6
19turner73
19turner73's Avatar
Year: 1989
Make: Ford
Model: Bronco II
Engine: 4.0L
Class: 2wd
First of all...thank for all the speedy replies to everyone.
yesterday I put the rear end up on jack stands and the pass. side axle slides in and out about 3/16". secondly...when I turn the driver tire. It turns about 10° before the pass. side tire starts to move. So...there is a good bit of slack between the differential. As, for the drive shaft....I ripped the CV joint style out months ago. replaced it with one with u joints.
Old 06-22-2012, 11:11 AM   #7
Shran's Avatar
Default
You know that there is naturally some play with those shafts, right? They MUST have some play so that you can get the c-clips in and out.
Also, both tires should not turn at the same time unless you have a locking differential.
Sounds pretty normal to me. Vibration is usually not a symptom of worn differential bearings anyway.
__________________
Old 06-22-2012, 11:40 AM   #8
Tracked and Locked
Asteroids Champion
adsm08's Avatar
Year: 1987
Make: Ford
Model: Ranger XLT
Class: 4x4
Used For: Elevenses
Default
Quote:
If he left it in gear and the trans is holding the drive shaft still the other wheel will spin in the opposite direction as which point 10* is still not bad.
If you had a trac-lok rear they should both spin together in the same direction. If you have an open rear it will need to take up a little slack (gotta have some space for oil to get between the gears) and then the other tire will spin in the oppostie direction.
Keep in mind that what amounts to thousandths of an inch of play at the gears themselves will multiply out and become inches by the time you get to the wheel because the wheel is much bigger around than the ring gear (see "radial vs linear distance"). The only true way to measure the slack in the rear end and see if it is out of spec is to set up a dial indicator on a tooth of the rigng gear and then rock the ring back and forth, see how far it moves before making contact with the pinion.
__________________
Old 06-22-2012, 10:53 PM   #9
509lifted
509lifted's Avatar
Year: 1984,1992
Make: ford
Model: bronco 2, eb explorer
Engine: 2.8l, 4.0 v6
Class: 4x4
Used For: stock right now besides sound system and air horn and push bumper
509lifted is a jewel in the rough509lifted is a jewel in the rough509lifted is a jewel in the rough
Default
first off check ur driveshaft and see if its true and straight cause i didnt know what the vibration was in the back of my b2 and then my driveshaft broke after two months of that happening and now the vibration is gone found out my driveshaft was .09 off as it was tweeked a bit.
509lifted is offline   Reply With Quote
Old 07-09-2012, 02:53 PM   #10
19turner73
19turner73's Avatar
Year: 1989
Make: Ford
Model: Bronco II
Engine: 4.0L
Class: 2wd
Default Rear end??? No No NO check the u Joints.
Hey Guys,
Man you guys are awesome!!! At my mistake. My problem turned out to be a U-Joint. lol
I guess the reason I was looking at the rear end is because, the axle slides out of the rear end about .25" on the pass. side. I have owed and worked on Fords for the better half of my life. Knowing that there is some slack in this application, but normally not as much as I am experiencing. Normally about an eighth of an inch. Thus causing me to think that this was the vibration. Stupid U-Joints.
My B2 is 2WD and yes it did come with the CV style drive shaft. Yeah...Well that shaft lasted about a week w/ my heavy foot and a freshly rebuilt 4.0l out of an '92 Explorer. I heard the ball bearings hitting the undercarriage of my truck lol. I replaced it w/ one from a 4WD B2. All is good now.....Thank you very much for your insight! I Love this site!!!!!
I have some other concerns with my trans. It's the FM145. I prob. should make a different thread....
Old 07-09-2012, 09:09 PM   #11
Shran's Avatar
Default
Glad to hear that you got it fixed
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2012 / 959 Media LLC / All Rights Reserved
[Legal Notices]   [Advertising/Vendors]
Also check out SSP Central for Special Service & Non-Traditional Police & Fire Vehicles
