| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
Year: 2005
Make: Ford
Model: Ranger Edge 2WD
Rep Power: 0 ![]() iTrader: (0)
Hey guys, I don't know much about brakes and was hoping those that know more than me could help me out.
I took the danger ranger in the dirt (a really bumpy recently disked field) two days ago for a little fun in the sun. Now whenever I slow down from around 65, they pull to the left. Can somebody clue me in as to what causes this, how to fix it, and what I can do to prevent it? Because hopefully soon, this truck will be seeing a lot more time in the dirt and I don't want this to be a reoccurring issue. Thanks |
Tweet
#2 | |
Tracked and Locked
Year: 1987
Make: Ford
Model: Ranger XLT
Engine: What engine?
Class: 4x4
Used For: Elevenses
Rep Power: 94 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (13)
Brake pull is usually caused by one wheel slowing down faster than the other. Pull the left wheel off and look for crap in the brakes.
It can also be caused by loose steering linkages.
__________________
Project: Hillbilly Deluxe Project: Amazing Grace Project: 12-Volt Sandwich Quote:
HELP REPEAL OBAMACARE Looking for 95-98 manual trans pedal bracket. Conducting an experiment for the betterment of all Ranger-kind. |
Tweet
#4 |
Year: 2005
Make: Ford
Alright, Here's the update I promised. Looks like adsm08 was right. So thanks a lot for the help. I've been really busy with class and work and stuff, so i did the quick fix (pressing on the brake and doing a slow crawl for about 25 yards). That stopped the squeal and shortly after the brake pull stopped. Also, I washed my truck, so maybe the water helped get the dirt out. Anyways, pretty much fixed itself. But 100,000 is coming up and the ranger's going under the knife for a good overhaul haha.
Tweet
#5 |
RBV Technical Advisor
Year: 1987... sorta
Make: Ford
Model: Ranger Supercab
Engine: '93 4.0
Class: 4x4
Used For: Roadtrip Warrior
Rep Power: 47 ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (18)
On an '05 I'd pull both wheels.
Unbolt both calipers Check for free range of motion on both caliper pins on each caliper bracket. And I'd remove both anti-rattle clips and check to see if rust on the bracket is causing the pads to bind against the caliper bracket. Only at that point would I start looking at the caliper pistons AD
__________________
Gun Control - A theory espoused by some monumentally stupid people; who claim to believe, against all logic and common sense, that a violent predator who ignores the laws prohibiting them from robbing, raping, kidnapping, torturing and killing their fellow human beings will obey a law telling them that they cannot own a gun. |
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
