| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
Year: 1991
Make: Ford
Model: Ranger Supercab
Engine: 1991 5.0 H.O. carbureted
Class: 2WD
Used For: getting attention
Rep Power: 4 ![]() iTrader: (0)
Have a 91' V8 ranger. Unfortunately I just burned a bearing and rathe than rebuild the motor going to pick up another from the junkyard I been eyeing up. It's a 5.0L HO from a 91 mustang. My ranger is set up for a carbureted V8. Will I be ruining this HO motor by putting my carb setup on it?
Tweet
#2 |
Year: 1985
Make: Ford
Model: Ranger
Engine: 5.0
Class: 4x4
Used For: A weapon of massive consumption.
Rep Power: 51 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
Nope, just make sure you have the right gear on your distributor and you should be good to go.
__________________
1985 Ford Ranger Custom, 4x4, PA 3" BL, 5.0 HO wannabe, C5 Transmixer, 31 spline T/L 8.8 w/ disc brakes. Build Thread My Ranger is not old; no one would call her old. She has a bluff bow, lovely lines. She's a fine truck: weatherly, stiff and fast... very fast, if she's well handled. No, she's not old; she's in her prime. |
Tweet
#4 |
Year: 1986
Make: Ford
Engine: 2.9L V6
Class: 4x4
Used For: DD/weekend toy/work
Rep Power: 12 ![]() iTrader: (1)
Could you elaborate? I've got a 5.0 that was given to me and I'm thinking if I decide to use it I'll just switch to a carb for simplicity. Thanks
__________________
1987 Supercab STX-3" BL -2.9L -FM145 -BW1350M -3.45's -7.5 rear -D28 front -30X9.50 AT 1985 Standard Cab Long Bed-8" lift -'93 4.0L -M5OD -BW1356M -3.73's -7.5 rear -D28 front -33X10.50 BFG MT |
Tweet
#5 |
5.0 HO under the hood!!!
Year: 1983
Make: Ford
Model: Ranger
Engine: 5.0 HO carbed with an np435 and np208
Class: 4x4
Used For: My DD, play toy
Rep Power: 32 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (1)
Non roller block engines need to have a cast iron gear on the dizzy while roller block engines need a steel gear.
Also not all roller block 302s are HO and HO engines have a different firing order then non HO 302s. Sent from my SGH-T499 using Tapatalk 2
__________________
Build thread, 5.0 swap happening now!!!! Click me 5.0 HO carbed, np435 with an np208 transfercase, 32 inch BFGoodrich M/T's, D30 SAS with 6.5 XJ coils, 63 inch leaves in rear. |
Tweet
#6 |
Year: 1985
Make: Ford
Model: Ranger
Engine: 5.0
Class: 4x4
The flat tappet cams use a cast iron gear and the roller cams use a steel gear.
__________________
Tweet
#7 |
Year: 1991
Make: Ford
Class: 2WD
Going to use the same intake, carb, distributor setup I'm running now but it's got a Cast iron gear. Is it east to replace with the steel gear or do I have to get a new distributor?
Tweet
#8 |
Year: 1983
Make: Ford
Model: Ranger
Class: 4x4
You cant put a steel gear on a dizzy with cast iron and vise versa. But I have heard that you can put a brass gear in place of either and be good but not sure on the life of a brass gear.
In the end, it would be easier to get a new dizzy. Heres a link to the one that I will be using. They say it has the steel gear for the HO engines. Also it is an HEI unit too. I wanted to keep it simple and whatnot plus had a guy that I know say that he has been using it for 2 years now without any problems. http://www.ebay.com/itm/FORD-289-302...efba11&vxp=mtr Plus was also told these units can have the brass gears put on them too.
__________________
Tweet
#9 |
Junior Member
Year: 1984 Ranger
Make: 1988 Ranger
Model: 1953 F100
Rep Power: 8 ![]() iTrader: (0)
You need the distributor gear, or a distributor your choice, from a 1986 Mustang GT 5.0L Carbed, manual transmission............ only choice for a stock gear/distributor that I know of.
I could have got the gear for @$75 a whole new distributor was @$95. I figured it was worth the $20 to avoid swapping the gears :-) |
Tweet
#10 |
Year: 1985
Make: Ford
Model: Ranger
Engine: 5.0
Class: 4x4
A brass gear will not last as long as steel, obviously they are quite a bit softer.
If you are getting a different dizzy go ahead and get a steel gear. It was a $20 difference for me too, I just got a rebuilt dizzy.
__________________
Tweet
#11 | |
December 2011 STOTM Winner
Year: 1997
Make: Ford
Model: Ranger
Engine: 5.0L HO, GT40 heads, GT40 intake, 65mm TB, 1.7rr, Tri-Y headers, dual 2.5" exhaust, Flowmaster muffl
Class: 2wd
Rep Power: 13 ![]() ![]() iTrader: (0)
Quote:
__________________
97 Supercab 5.0 H.O. EFI Tri-Y Headers T-5 DJM 5/8 Drop Cal-Vu mirrors, Shaved badges. Explorer interior 18X9/18X10 Bullitt wheels (275/40, 295/35) 5.0 link |
Tweet
| Bookmarks |
| Tags |
| 1991, mustang |
| Thread Tools | |
| Display Modes | |
