Serving Ford Ranger, Bronco II, Explorer & Mazda B-Series Owners Since 1999
Home Forums Info - Technical Info - Other TRS News Photo Galleries Shirts & Decals Parts Store Classifieds
Go Back   The Ranger Station Forums > Bulletins (Welcome, News/Announcements, Problems & Submissions) > Submit Info For Tech Library Or Magazine
Notices
Submit Info For Tech Library Or Magazine Submit all your technical information or stories here to be added to our Technical Library or online TRS Magazine.
DO NOT POST TECH QUESTIONS HERE!
Click HERE for our Tech Library
Click HERE for our Resources Section
Click HERE for our online Magazine
Post New Thread Reply
Thread Tools Display Modes
Old 06-26-2012, 05:38 PM   #1
Tracked and Locked
Asteroids Champion
adsm08's Avatar
Year: 1987
Make: Ford
Model: Ranger XLT
Engine: What engine?
Class: 4x4
Used For: Elevenses
adsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond repute
Send a message via AIM to adsm08
Default Cordless tool battery repair
Original Poster: ADSM08
Difficulty: 3 out of 10
Time to Complete: 15 minutes. I did it while making dinner and playing fetch with the dogs.
Disclaimer: The Ranger Station.com, The Ranger Station.com Staff, nor the original poster are responsible for you doing this modification to your vehicle. By doing this modification and following this how-to you, the installer, take full responsibility if anything is damaged or messed up. If you have questions, feel free to PM the original poster or ask in the appropriate section of The Ranger Station.com forums.
Additionally you are dealing with a battery and heat. BE CAREFUL. Do not allow the iron to sit on the terminal longer than needed.
Brief Explanation: This is how to repair terminal connections on cordless tool batteries that may have been damaged. This applies specifically to the Snap-on 14.4V High Output battery, but may work for others as well.
In the case of my battery it would operate intermittently. Smacking it would make it work for a little bit, but it rarely stayed working for more than a few seconds. It was damaged after being dropped.
Tools Needed:
- Appropriate sized torx or screw driver
- Soldering iron
- Voltmeter
Parts Needed:
- Solder
Steps 1: Open battery case. There is usually screw access from the bottom. The holes may be hidden under the sticker.
Steps 2: Identify the damage. This can be done by using a volt meter hooked to one tool terminal and the sides of the individual cells. Move from one to the other until you don’t read power.
In my case the solder points of the positive terminal had been damaged by the initial impact when I dropped the gun, and then broken completely by the vibrations of the tool.
Steps 3: Solder the damaged connector back together. Given the safety issues involved in soldering directly on a battery I made a big solder booger and flung it onto the counter to make it flat. Then I pulled the terminal up, stuck the booger under it, and held the iron on the terminal until the solder melted.
I did not take pictures during that part of the process for safety reasons. This pic was taken with the iron cold and unplugged.
Use your volt meter to test the battery across the tool terminals to make sure the repair is complete.
Then allow the solder to cool and put the battery case back together by reversing the process for disassembly.
__________________
__________________
Project: Hillbilly Deluxe
Project: Amazing Grace
Project: 12-Volt Sandwich
Quote:
Originally Posted by Mark_88 View Post
Question: "What year is your truck"?
My Answer: "What part"?
Quote:
Originally Posted by John Adams
Our Constitution was made only for a moral and religious people. It is wholly inadequate to the government of any other.
HELP REPEAL OBAMACARE
Looking for 95-98 manual trans pedal bracket. Conducting an experiment for the betterment of all Ranger-kind.
adsm08 is online now   Reply With Quote
Old 06-27-2012, 04:58 PM   #2
daniel3507
daniel3507's Avatar
Year: 1993
Make: Ford
Model: Ranger XLT
Engine: 4.0
Class: 2WD Off-Road
Used For: truckin around
daniel3507 has a brilliant futuredaniel3507 has a brilliant futuredaniel3507 has a brilliant futuredaniel3507 has a brilliant futuredaniel3507 has a brilliant futuredaniel3507 has a brilliant futuredaniel3507 has a brilliant futuredaniel3507 has a brilliant futuredaniel3507 has a brilliant futuredaniel3507 has a brilliant futuredaniel3507 has a brilliant future
Default
Nice write up. That's a common problem with batteries that have terminals like that. Cant even begin to tell you how many i had to fix when I used to rebuild batteries at work. And for anyone thinking about doing this do not ignore the safety issues mentioned in step 3. The way he described is the best way to secure the terminals if you dont have a spot weld machine.
__________________
Quote:
Originally Posted by BlackBII View Post
I pretty much wear a bicycle helmet with stickers on it every where I go...so yeah.
Show Off Thread
Build Thread (click)
1993 Ranger XLT 4.0, 20% tint, 2'' spacers, RS9000XL adjustable front shocks, Bilstein rear shocks, 4.10 gears, 31'' tires, 15'' Alcoa's, custom front shackles, Lvl II rear tow hook, 2.25'' exhaust w/ Super 44, Screamin' Demon coil pack, slotted rotors w/ EBC Greenstuff, Delta Cam rockers and pushrods
daniel3507 is offline   Reply With Quote
Old 06-27-2012, 05:28 PM   #3
88_Eddie
Motorboater (.Y.)
Chopper Challenge Champion
88_Eddie's Avatar
Year: 1988, 2000
Make: Ford
Model: Bronco II (Eddie Bauer), Explorer
Engine: 2.9L, 4.0L
Class: 4x4, 2WD
Used For: Annoying the old ball and chain.
88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute
Default
interesting, i think have a battery kicking around that wont take a charge. thanks ad
__________________
BUILD THREAD<<<<<<<<<<<<<
The Tikki Torch Build Thread
1988 Bronco II 4x4 2.9, FM146, 1350M, Disc 8.8, D30 SAS, 3.73's, 31's (for now)
2000 Explorer 4.0 2WD DD
Everything I need to know about Islam, I learned on 9/11.
The hardest part about a zombie apocalypse will be pretending I'm not excited.
Quote:
Originally Posted by Wedding Crashers
What'd you do with them? Motorboat? You play the motorboat? You motorboatin son of a bitch! You old sailor you!
Quote:
Originally Posted by jammert609@yahoo.com View Post
I am being told by family an friends my truck is a piece of shit
88_Eddie is offline   Reply With Quote
Old 06-27-2012, 07:15 PM   #4
Tracked and Locked
Asteroids Champion
adsm08's Avatar
Year: 1987
Make: Ford
Model: Ranger XLT
Class: 4x4
Used For: Elevenses
Default
Best part it, that battery would maybe work for 20 seconds at a time before. I used it all day today without a problem.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2012 / 959 Media LLC / All Rights Reserved
[Legal Notices]   [Advertising/Vendors]
Also check out SSP Central for Special Service & Non-Traditional Police & Fire Vehicles
