Serving Ford Ranger, Bronco II, Explorer & Mazda B-Series Owners Since 1999
Home Forums Info - Technical Info - Other TRS News Photo Galleries Shirts & Decals Parts Store Classifieds
Go Back   The Ranger Station Forums > Truck Discussions > General Discussions
Notices
General Discussions This forum is for general discussions. Place posts that don't fit in any other forums here.
Post New Thread Reply
Thread Tools Display Modes
Old 06-22-2012, 02:52 AM   #1
c.tite.13@hotmail.com
Year: 1988
Make: Ford ranger xlt
Model: 1988 Ford Ranger xlt manual trans 2.9l
c.tite.13@hotmail.com is on a distinguished road
Default 1988 xlt ranger 4x4 2.9l manual trans
i have a 1988 ford ranger xlt 2.9l manual trans, the clutch was just replaced. i was driving today and i hear a grinding sound, the engine runs perfect starts every time, i can feel the clutch is there but when i go to put it in gear it doesnt move and only revs. i had the truck running and drove as i would normally and it caught in the top end of fourth only to move and make the grinding sound, it is now parked could this be my transmission? any suggestion i need to figure this out asap this truck pays the bills..
c.tite.13@hotmail.com is offline   Reply With Quote
Old 06-22-2012, 04:54 AM   #2
lil_Blue_Ford
lil_Blue_Ford's Avatar
Year: 95
Make: Ford
Model: F-150
Engine: 4.9L
Class: 4x4
Used For: Work
lil_Blue_Ford is a splendid one to beholdlil_Blue_Ford is a splendid one to beholdlil_Blue_Ford is a splendid one to beholdlil_Blue_Ford is a splendid one to beholdlil_Blue_Ford is a splendid one to beholdlil_Blue_Ford is a splendid one to beholdlil_Blue_Ford is a splendid one to behold
Send a message via AIM to lil_Blue_Ford
Default
It could be a problem with the clutch.... or it could be a transmission problem... or stripped gears in the rear axle...or....
Need more information, basically.
Can you put the shifter in a gear?
If it is 4x4, is the transfer case engaged? (and is it a 4x4?)
If it is 4x4, does putting it in 4x4 make it move?
With the truck off and in gear, climb under the truck and check the driveshaft(s) for play (both wiggle it and check for U-joint wear and see if it will turn).
Block the front axle, jack up the rear axle (USE JACKSTANDS), and see if the driveshaft will turn by hand with the transmission in gear. Check both wheels for sloppy movement.
Put it back down and pull the rubber plug on the bellhousing (if equipped) use a flashlight to look at the clutch while someone works the clutch pedal and verify movement.
I'm sure I'll think of something else to check.... but we'll start there...
__________________
"lil Blue" 2000 Ranger Supercab xlt: 3.0L, 5-spd, 2wd
"S**tbrick" 1988 Bronco II Eddie Bauer: 4.0L, auto, 4x4
1989 Bronco II choptop: 2.9L, 5-spd, 4x4, 7" lift, locked f/r, 33's
"Phoenix" 1986 Bronco II xl: 2.9L, auto, 4x4 (future trail toy)
1989 Ranger parts donor: 4cyl, manual trans, 4x4
Quote:
Originally Posted by JohnnyO View Post
Some people are too stupid to be in management. That's why they keep getting promoted.
lil_Blue_Ford is offline   Reply With Quote
Old 06-22-2012, 09:54 AM   #3
Year: 1988
Default
hey so i no its not the cluttch the clutch is brand new and my drive shaft and u joint seem fine. i can feel it right under my feet when it happend it will go in gear but but i let the clutch out it just revs and no movement...tranny?
Old 06-22-2012, 09:55 AM   #4
Year: 1988
Default
and i tried sticking it in four weel to move the front weels but no movement which has made me think its my tranny..?
Old 06-22-2012, 12:29 PM   #5
Brownie Mobile
Brownie Mobile's Avatar
Year: 1984
Make: Ford
Model: Bronco II
Engine: 2.8l
Class: 4x4
Used For: To take up space in my driveway
Brownie Mobile is on a distinguished road
Default
Quote:
Doesn't mean its not the clutch. Was it running fine before you put the clutch in? if so wouldnt the obvious conclusion be that you put the clutch in wrong?
__________________
Quote:
Originally Posted by stegomon View Post
but did it have a rocket launcher?
Quote:
Originally Posted by ASMODEAN View Post
No but I bet it had leaky valve covers and a noisy power steering pump...
Brownie Mobile is offline   Reply With Quote
Old 06-22-2012, 12:44 PM   #6
Year: 1988
Default
i dont no i bought it a month ago with the a brand new clutch put in it. there is pressure on the clutch everything inside looks fine...it just wont go, when i put it in gear and give it gas it makes a grind noise kinda..maybe no tranny fluid??
Old 06-22-2012, 01:12 PM   #7
Jraymer360
Jraymer360's Avatar
Year: 1993
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4X4
Used For: Soon to be a daily driver
Jraymer360 will become famous soon enoughJraymer360 will become famous soon enough
Default
Did you check the fluid??
__________________
1993 Ford Ranger Ext cab, 4x4, 4.0, auto, manual hubs, 6 inch lift, ton's of things wrong and it'll probably go to my brother!
1999 Ford Ranger Ext cab 4x4, 4.0, 5 speed, Stock stock stock!
Jraymer360 is offline   Reply With Quote
Old 06-22-2012, 02:58 PM   #8
Redneckryder
Guilty by association
Redneckryder's Avatar
Year: 1993
Make: Ford
Model: Ranger STX X-Cab
Engine: 4.0
Class: 4x4
Used For: Whatever the wife won't let me do in the Jeep.
Redneckryder is a jewel in the roughRedneckryder is a jewel in the roughRedneckryder is a jewel in the rough
Send a message via Yahoo to Redneckryder Send a message via Skype™ to Redneckryder
Default
It could be your transfer case. Mine was messing up, seemed to pop out of gear and it ended up being a stripped something or other in the t-case. Jack up the rear axle, put it in gear, spin the wheels. see if they spin without the engine turning over. It will give you somewhere to start....
__________________
Only 2 defining forces have ever offered to die for you.....Jesus Christ and the American Soldier.
One died for your soul, the other for your freedom.
Got a new ranger....
Redneckryder is offline   Reply With Quote
Old 06-22-2012, 03:38 PM   #9
Year: 1988
Default
so i checked the fluid there is fluid in there but it also has metal slivers in it and it is auto atf red fluid.... now i really think its the tranny..?
Old 06-22-2012, 03:42 PM   #10
Tracked and Locked
Asteroids Champion
adsm08's Avatar
Year: 1987
Make: Ford
Model: Ranger XLT
Engine: 2.9 High Performance
Class: 4x4
Used For: Elevenses
adsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond repute
Send a message via AIM to adsm08
Default
If it grabs but grinds in 4th and acts like it is in neutral in all other gears the transmission is at fault. Specifically the counter shaft is not engaging properly to one of the other two.
__________________
Project: Hillbilly Deluxe
Project: Amazing Grace
Project: 12-Volt Sandwich
Quote:
Originally Posted by Raj
What you need is cheat codes, motor skills, and a magic genie who grants wishes to little boys who suck at Mario Kart
Quote:
Originally Posted by John Adams
Our Constitution was made only for a moral and religious people. It is wholly inadequate to the government of any other.
HELP REPEAL OBAMACARE
Looking for 95-98 manual trans pedal bracket. Conducting an experiment for the betterment of all Ranger-kind.
adsm08 is online now   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2012 / 959 Media LLC / All Rights Reserved
[Legal Notices]   [Advertising/Vendors]
Also check out SSP Central for Special Service & Non-Traditional Police & Fire Vehicles
