| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| Ranger Axles Dana 28, Dana 35, Ford 7.5 & Ford 8.8 |
Thread Tools | Display Modes |
#49 |
WRENCH WERKS
Year: 1994
Make: FORD
Model: RANGER
Engine: 3.0L
Class: 2WD OFF ROAD
Used For: EVERYTHING A RANGER CAN DO, AND LOTS OF THINGS IT SHOULDN'T
Rep Power: 18 ![]() ![]() iTrader: (0)
No breather that i know of, just the fill plug and the seal. Ive got 2 parts trucks i can scavenge from this weekend, one is probably in worse shape but theres hope in the second one, plus i ned to steal the swaybar links off said truck so i can extend them and put my sway bar back on, freeway ramps are a little sketchy without them, im sure the lockrite isnt helping me there either.
__________________
1994 Ranger 4X2 Off Road, Built Not Bought! http://www.therangerstation.com/foru...ad.php?t=37621 |
Tweet
#50 |
Premium Member
Year: 1994
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Used For: daily driver, trail ready
Rep Power: 8 ![]() ![]() ![]() ![]() ![]() iTrader: (1)
The lockrite shouldn't make a difference on handling, sway bars definitely will though.
Sent from the road while ignoring traffic |
Tweet
#51 |
WRENCH WERKS
Year: 1994
Make: FORD
Model: RANGER
Engine: 3.0L
Class: 2WD OFF ROAD
Heres the pic of my oil leak, i didnt touch the oil level between when i cleaned the wheel and when i took the picture, so ive got about 100 miles worth of leak here.
![]() ![]() ![]() Heres the passenger side for comparison, no leaks since i installed them
__________________
Tweet
#52 |
WRENCH WERKS
Year: 1994
Make: FORD
Model: RANGER
Engine: 3.0L
Class: 2WD OFF ROAD
Im just not as good as i once was, its been at least 2 weeks since i said i was going to swap spindles but life just keeps getting in the way of truck stuff. Im in the process of buying my first house so most of my free time has been occupied by running around and signing papers and calling people, not to mention its been 100* for the past 2 weeks so my motivation to sweat over the parts truck just hasnt been there. Im adding oil every couple days so keep the hub full and the bearings happy but i will get this problem fixed and then post up a few pics of clean, properly functioning oil bath hubs on my 2wd ranger!
__________________
Tweet
#53 | |
Year: 95
Make: Ford
Model: F-150
Engine: 4.9L
Class: 4x4
Used For: Work
Rep Power: 26 ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (5)
Quote:
Now to just figure out a way to make it work with a 4x4.... it would be nice to not have to deal with packing bearings with grease all the time...
__________________
"lil Blue" 2000 Ranger Supercab xlt: 3.0L, 5-spd, 2wd "S**tbrick" 1988 Bronco II Eddie Bauer: 4.0L, auto, 4x4 1989 Bronco II choptop: 2.9L, 5-spd, 4x4, 7" lift, locked f/r, 33's "Phoenix" 1986 Bronco II xl: 2.9L, auto, 4x4 (future trail toy) 1989 Ranger parts donor: 4cyl, manual trans, 4x4 |
Tweet
#54 |
Year: 1992
Make: FORD
Model: RANGER
Engine: 4.0
Class: 4x4 extreme
Used For: work and trail ridin and everything in between
Rep Power: 0 ![]() iTrader: (0)
i have read every page of this forum and i have to say damn good job this has really gien me the motivation to get out there and fix the problems on my ranger and keep goin that si one nice ranger
__________________
1992 ford ranger 4 in rough country lift 32inx11.50x15 on 15x10 aero dirt track rims super offset |
Tweet
#55 |
WRENCH WERKS
Year: 1994
Make: FORD
Model: RANGER
Engine: 3.0L
Class: 2WD OFF ROAD
thanks man, i wish i could still be a part of TRS like i used to be, but life has me in a different spot now than i used to be in. like i said earlier im buying a new house so im going to have a new work shop to start blooming new ideas in so you guys definately havent seen the last of me, im just on a "working vacation" so you can bet when i make my return ill be back in full swing! that reminds me i need to update the build thread with some relevant truck things
__________________
Tweet
#56 |
WRENCH WERKS
Year: 1994
Make: FORD
Model: RANGER
Engine: 3.0L
Class: 2WD OFF ROAD
victory at last, the hi temps finally broke and i got work done. heres my two specimens, one from a 90' and one from a 94'. i cleaned the best looking one up and welded up the wear areas from the inboard brake pad, now i just have to grind-to-fit with an old brake pad and then i can swap ball joints and hope this fixes the leak.
![]() ![]() the only difference i noticed between the 90' and the 94' was on the back side of the knuckle where the spindle is swedged to the knuckle, on the 90' it has a tapered hex and on the 94 it has a uniform hex shape inside of a raised and machined nub. ![]() ![]() i measured this spindle with micrometers and compared the measuments to BCA / Nationals' published bearing and seal dimensions and everything is within spec so now i just need another window of opportunity to swap out the bad one for the good one
__________________
1994 Ranger 4X2 Off Road, Built Not Bought! http://www.therangerstation.com/foru...ad.php?t=37621 Last edited by ForOffRoadDriving; 07-09-2012 at 07:39 PM. |
Tweet
| Bookmarks |
| Tags |
| greaseless wheel bearings, oil bath hubs, xl pro lube 1980 |
| Thread Tools | |
| Display Modes | |
