Serving Ford Ranger, Bronco II, Explorer & Mazda B-Series Owners Since 1999
Home Forums Info - Technical Info - Other TRS News Photo Galleries Shirts & Decals Parts Store Classifieds
Go Back   The Ranger Station Forums > Engine & Transmission Forums > Transmissions
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 04-01-2012, 07:00 PM   #109
supersamikc
supersamikc is on a distinguished road
Default
did you run your stock 4.0 inspection plate?
supersamikc is offline   Reply With Quote
Old 04-01-2012, 07:58 PM   #110
Rulebreaker
Rulebreaker's Avatar
Year: 1993
Make: Ford
Model: Broncostar
Engine: 4.0L
Class: 4x4 Extreme
Used For: offroading family style
Rulebreaker is on a distinguished road
Default
Quote:
yes
__________________
93 Aerostar 4.0L Np435 8.8" with 4.11's D44 SAS Locked F&R 22" lift 35" claws and a Warn 8000 All
89 B2 RIP
98 Ranger 4x2 3.0L
Rulebreaker is offline   Reply With Quote
Old 06-20-2012, 10:50 AM   #111
supersamikc
Default
another question for someone, could you run a small block c6 behind it?
Old 06-20-2012, 05:13 PM   #112
Rulebreaker
Year: 1993
Make: Ford
Model: Broncostar
Engine: 4.0L
Class: 4x4 Extreme
Default
I'd sell you just the adapter plate if you want to figure out a way to hook a C6 converter to a 4.0L flex plate. I'm guessing you would need an adapter plate for the 4.0L flex plate. 435 has much better gearing so thats the best way to go for gearing purposes. RB
__________________
89 B2 RIP
98 Ranger 4x2 3.0L
Old 06-20-2012, 08:48 PM   #113
Shran's Avatar
Shran will become famous soon enough
Default
What vehicle did your slave cylinder come from? I need to do something different with mine, the clutch pedal is insanely hard to push. I'm using a '75 Toyota Land Cruiser slave right now.
__________________
1986 Ranger XL 4x4, 302, NP435/205, HP D44, RCV shafts, 8.8 Lock-rite/lsd, 4.10 gears, 35" BFG M/T --- Build Thread
1996 Ranger XLT 4x2, 2.3, M5OD
1986 F150 4x2 302/T18
1985 F250 4x4 460/T19
Shran is offline   Reply With Quote
Old 06-20-2012, 09:15 PM   #114
Rulebreaker
Year: 1993
Make: Ford
Model: Broncostar
Engine: 4.0L
Class: 4x4 Extreme
Default
http://http://www.ebay.com/itm/PULL-..._Parts&vxp=mtr
__________________
89 B2 RIP
98 Ranger 4x2 3.0L
Old 06-20-2012, 10:02 PM   #115
Shran's Avatar
Default
Nice, thanks! How does your clutch pedal feel? I am going for as light as possible.
__________________
Old 06-21-2012, 08:40 AM   #116
Rulebreaker
Year: 1993
Make: Ford
Model: Broncostar
Engine: 4.0L
Class: 4x4 Extreme
Default
The feel is more about the master/slave relationship. I think a smaller master bore is easier than a large master bore. So a 5/8 master would be easier to push than say a 7/8. I'm saying this all by memory from a truck I worked on years ago so dont quote me on this.
__________________
89 B2 RIP
98 Ranger 4x2 3.0L
Old 06-21-2012, 11:47 AM   #117
Shran's Avatar
Default
Been doing some research to refresh my memory today since the current master/slave has been in the truck for two years.
Speedway had good documentation for their slave cylinders (which look exactly like the eBay one above) and they recommend using a 3/4 bore master and a 7/8 bore slave with 3/16 hose. If you want quicker clutch action, use a 1/4 hose.
Looks like it has something to do with volume of fluid - ie, small (3/4 bore) pushing large (7/8) or vice versa.
Factory Ranger master cylinders are 3/4 bore, and my Toyota slave is 3/4 bore so I believe that is my problem. Will be ordering a new slave shortly.
__________________
Old 09-10-2012, 10:29 AM   #118
Shran's Avatar
Default
I finally got around to fixing my slave cylinder issue and thought I'd add the solution here since it is relevant. So far so good, pedal is much easier to push and the clutch feels like it just works better.
Speedway sells a 7/8 bore push slave cylinder that I bought. The bracket was very easy to build, just a piece of angle iron with 4 holes drilled in it. I reused the fittings and push rod from my Toyota slave. The only other comment I have is that you MUST use the '82-up bellhousing that has the slave cylinder mounts cast into it.
Link to the one I bought:
http://www.speedwaymotors.com/Push-T...nder,1944.html
__________________
Old 10-09-2012, 10:01 PM   #119
supersamikc
Default
what have you guys been doing for exhaust, or manifolds? my manifolds exit pretty close to the adapter and do not leave much or any room to run the down pipes. motor isout of a 93 ranger 4.0 stock manifolds
Old 10-17-2012, 08:03 PM   #120
supersamikc
Default
anyone????
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2012 / 959 Media LLC / All Rights Reserved
[Legal Notices]   [Advertising/Vendors]
Also check out SSP Central for Special Service & Non-Traditional Police & Fire Vehicles
