| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| Towing For questions about towing or to show off your tow rig. |
Thread Tools | Display Modes |
#13 |
Year: 1985
Make: Ford
Model: Ranger
Engine: 5.0
Class: 4x4
Used For: A weapon of massive consumption.
Rep Power: 51 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
My '02 5.4 4x4 on stock rubber put down a pretty reliable 18-19mpg.
Never tied into an enclosed trailer, just flatbeds with machinery on board... low teens but it was a lot heavier than two horses in a horse trailer.
__________________
1985 Ford Ranger Custom, 4x4, PA 3" BL, 5.0 HO wannabe, C5 Transmixer, 31 spline T/L 8.8 w/ disc brakes. Build Thread My Ranger is not old; no one would call her old. She has a bluff bow, lovely lines. She's a fine truck: weatherly, stiff and fast... very fast, if she's well handled. No, she's not old; she's in her prime. Last edited by 85_Ranger4x4; 06-17-2012 at 12:27 PM. |
Tweet
#14 | |
Location: People's Republic of Michiganistan, United Socialist Republic of America
Year: 99, 96
Make: Lincoln, Ford
Model: Continental, F350 CC dually
Engine: 32v DOHC 4.6L V8, powerstroke
Class: fwd, 2wd
Used For: rice killer,Because I wanted it
Rep Power: 36 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
this is what I have discovered after 14 years of tractor trailer...... Drag is a bigger factor on mileage than weight over 50 mph. Under 50 mph then drag is no longer a factor.
I can take a Flatbed loaded 48000# of rebar where the load is only 16" tall the full length of the trailer and pull better fuel mileage than a 53' Van loaded with 9000# of foam. Conversely....... The van will get better mileage if I have to add a tarp...... dragging a load with a tarp is like pulling a parachute behind you.
__________________
Quote:
Tweet
#15 |
Year: 1985
Make: Ford
Model: Ranger
Engine: 5.0
Class: 4x4
Weight does matter to a certain degree, and it would be significant between my tractor/plow on a flatbed vs a couple horses in a trailer.
It is a lot easier to pull the empty trailer than it is with my 5000lb tractor on it.
__________________
1985 Ford Ranger Custom, 4x4, PA 3" BL, 5.0 HO wannabe, C5 Transmixer, 31 spline T/L 8.8 w/ disc brakes. Build Thread My Ranger is not old; no one would call her old. She has a bluff bow, lovely lines. She's a fine truck: weatherly, stiff and fast... very fast, if she's well handled. No, she's not old; she's in her prime. |
Tweet
#16 | ||
Year: 99, 96
Make: Lincoln, Ford
Class: fwd, 2wd
Quote:
that only matters to get it going, getting up/down the grade, and getting it stopped ....... once you are moving.... weight means less than drag.
__________________
Quote:
Tweet
#17 |
Premium Member
Year: 1998
Make: Ford
Model: Ranger XLT
Engine: swapped in a 4.0
Class: 4x4
Used For: daily driver,weakend trailrida!
Rep Power: 8 ![]() iTrader: (2)
ohh..i wasn't conserned with mpg. That 150 pulled that horse and didn't even feel the trailer. But when I was wondering if my Ranger could pull 2 horses, I didn't have the 150 at the time.
Regardless, I still wanna set it up with some temp guages, I do offroad alot, and I still want to set it up with a Class IV Reese hitch reciever. 35 ATs on 4.10s, I wouldn't choose to tow with the Ranger over the 150. haha
__________________
98 4.0 4x4, 4.10->SAS Dana44+Ford8.8, 4" suspy, 3" BL, 03 Frontend 35" BFG ATs http://www.cardomain.com/ride/3840375 Jэʀsэy ʀᴧɴɢэʀ сʀэW |
Tweet
#18 |
Year: 1984
Make: Ford
Model: Bronco II, 2.8LV6 4x4 5 speed
Engine: 2.8L
Class: 4x4
Used For: Work & Commuting
Rep Power: 4 ![]() ![]() iTrader: (0)
I pulled a 2 horse trailer with one horse around for a while behind my 84 ford ranger 4x2 with the 2.8L V6, did just fine with the 3 speed automatic. The newer model rangers with the 4.0L should have no problem with a 2 horse trailer with 2 horses, the weak link are the electronic automatic transmissions. Grandfather had a 93 ranger with automatic transmission and had it rebuilt when we drug it home from my uncles, 12,000 miles later it went out again, truck went bye bye, if it couldn't pull itself around without blowing a transmission it wasn't worth having. The 84 Ford Ranger also pulled around a 16' travel trailer for several years and never had a problem. I still miss that truck, but in about 8 days I'll have something close to it again, not the ranger but the bronco 2 version, which will become my daily driver.
Sorry from straying from the OP, but goes to show you don't need a fancy $60K+ truck to haul horses around with, and to those who do are just showing off, and apparently have more money than brains from the way I've seen them drive and act. |
Tweet
#19 |
Premium Member
Year: 1998
Make: Ford
Model: Ranger XLT
Class: 4x4
Well...Thats the first thing I learned about people who often tow. I've always used my Ranger for everything; vehicle recovery, hauling oak, trailering. But they'res always that guy in a brand new diesel that thinks only his truclk is capable prob because thats what the salemen told em'. lol
__________________
Tweet
#20 |
Year: 1984
Make: Ford
Engine: 2.8L
Class: 4x4
^^^No they just have too much green stuff in their wallet. I learned a long time ago, if you have xxx vehicle, don't buy something towable that xxx vehicle isn't able to handle. Seems like most people go out and buy a trailer whether it be an RV, flat bed, utility trailer, etc. then whine and cry because their Yugo won't pull whatever it was they bought LOL. I just picked up a 1964 Oasis 13 foot travel trailer, well sleep trailer, its not anywhere near self contained, has a stove non-working sink, and a bed. Good enough for me, beats sleeping on the ground. I have no problem towing it with my current truck, I even moved it around the yard a few times when I still had my Yamaha Rhino, so if my Yamaha Rhino could tow it I'm pretty sure I'm not going to have a problem towing this next camping trip after I get my bronco 2 home.
Basically, don't buy what you can't tow, plain and simple LOL. It doesn't matter which brand vehicle you buy, they all have maximum ratings for a reason, most 1/2 ton trucks now are rated to tow 10k+ but I don't think I'll be trying it, if I need to tow something that big I'll get a different vehicle, can't afford a different vehicle, so I stay within what the vehicle in my driveway can handle safely without pushing the safety envelope. Yeah I overloaded a 93 ford ranger once, stopping was scary, luckily it was on such a back road I didn't have to worry about traffic, would I do it on a highway, umm...he** no. The ranger handled it, yes, was it safe, not really, wouldn't have been a problem had I known the brakes on the trailer didn't exactly work, and wasn't towing a 2100lb trailer with a 1983 ford full size bronco on it behind a ranger. |
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
