lil_Blue_Ford
Cut & Weld
⭐Supporting Member
💻 TRS Socials
TRS 25th Anniversary
- Aug 6, 2007
- Butler
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Automatic
- Total Drop
- 4”
So I'm getting ready to put a cage in my choptop (finally). Gonna pull the windshield since it's broken and I'm inclined to go with a pre-fab cage from Jegs (Ranger cage, 10 point) as something to start with and I'll add whatever I need to make it suit my purposes. I figure for what it costs compared to what the cost of steel is locally, it's a good deal.
That said, I have some questions about making it all work the way I want it to.
The tube they use for the cage is 1 5/8 round .134 wall mild steel. I priced some out locally since I want to do an inverted V behind the front seats so it's easier to crawl into the back as well as doing a full cage in the back (like the Jeep family bar type), only thing is, locally that tube goes for $5.66 a foot and if I would get four sticks, that's nearly $500 bucks.
So I thought about trying to see if I can find something a little more reasonably priced, but I'm not sure if I should stick with the same diameter or if it will cause any problems to go slightly bigger/smaller, etc.
Also, the Jegs cage uses a Halo bar setup. Looking at where the front supports will come down, I can see that they will probably be pretty close to the dash. I don't really want to go through the headache of swapping out my dash now, but at some future point, it's probably going to get swapped out. I saw that a couple companies make a sort of cage joint that bolts together, so what I'm asking is if ya'll think it would be safe to use one of those joints up near the roof so that I can remove the front support bars at some future point for ease of replacing the dash. THESE are what I'm talking about.
Finally, (for now) comes the floor plates. Jegs includes some 1/8" thick plates with the cage and the instructions say to weld the plates to the floor. Eventually I'll probably make braces that go from the plates to the frame. Should I be using say a 1/4" thick plate? Should I just bolt it to the floor for now until I fab up the frame braces instead of welding?
So I thought about trying to see if I can find something a little more reasonably priced, but I'm not sure if I should stick with the same diameter or if it will cause any problems to go slightly bigger/smaller, etc.Also, the Jegs cage uses a Halo bar setup. Looking at where the front supports will come down, I can see that they will probably be pretty close to the dash. I don't really want to go through the headache of swapping out my dash now, but at some future point, it's probably going to get swapped out. I saw that a couple companies make a sort of cage joint that bolts together, so what I'm asking is if ya'll think it would be safe to use one of those joints up near the roof so that I can remove the front support bars at some future point for ease of replacing the dash. THESE are what I'm talking about.
