| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| Non-Ranger Axles All other axles. Ford 9-inch, Dana 44, Dana 60, etc. |
Thread Tools | Display Modes |
#1 |
Junior Member
Year: 1997
Make: Ford
Model: Ranger
Engine: Going 5.0
Class: 2wd street
Used For: paper weight
Rep Power: 12 ![]() iTrader: (0)
Does anyone know where I can buy a new backing plate/dust shield for a 97 explorer 8.8? Im having a hard time finding them online. This isn't a dealer item is it?
Tweet
#2 |
Coast Mountain Crawlers
Year: 1991/1997/2008
Make: Ford
Model: Ranger/Ranger/SuperDuty
Engine: 4.0L/3.0L/6.4L
Class: 4x4
Used For: Play toy/Daily Driver/Grocery Getter
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
I would think so.
__________________
http://www.coastmountaincrawlers.com 1991 Ranger - one tons, 3 link, air shocks and 40's 1997 Ranger - reg cab flare side, 3.0L, M5OD-R1, 4x4, 4.56 gears, 6" lift, 33" MT's. 2008 F350 - 6.4L Powerstoke Diesel, 35x12.50R18 Procomp Xtreem AT's on 18x9 Incubus Crushers, AFE DPF/DOC Delete pipe, H&S XRT Pro tuner, AFE Stage 2 intake 1967 Mustang Coupe - 289, c4, pretty much stock |
Tweet
#3 |
Junior Member
Year: 1997
Make: Ford
Model: Ranger
Engine: Going 5.0
Class: 2wd street
so ford wants pver $400 bucks for a pair...tasca wants about $300, all of a sudden the pair I have dont look so bad.
Tweet
#4 | ||
Tracked and Locked
Year: 1987
Make: Ford
Model: Ranger XLT
Engine: 2.9 High Performance
Class: 4x4
Used For: Elevenses
Rep Power: 93 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (13)
Keep in mind that the part Ford priced you isn't just the stamped steel backing plate. It is the whole, pre-assembled, parking brake.
__________________
Project: Hillbilly Deluxe Project: Amazing Grace Project: 12-Volt Sandwich Quote:
Quote:
HELP REPEAL OBAMACARE Looking for 95-98 manual trans pedal bracket. Conducting an experiment for the betterment of all Ranger-kind. |
Tweet
#5 | |
Motorboater (.Y.)
Year: 1988, 2000
Make: Ford
Model: Bronco II (Eddie Bauer), Explorer
Engine: 2.9L, 4.0L
Class: 4x4, 2WD
Used For: Annoying the old ball and chain.
Rep Power: 48 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (6)
LMC truck?
__________________
BUILD THREAD<<<<<<<<<<<<< The Tikki Torch Build Thread 1988 Bronco II 4x4 2.9, FM146, 1350M, Disc 8.8, D30 SAS, 3.73's, 31's (for now) 2000 Explorer 4.0 2WD DD Everything I need to know about Islam, I learned on 9/11. The hardest part about a zombie apocalypse will be pretending I'm not excited. Quote:
Tweet
#7 |
Junior Member
Year: 1997
Make: Ford
Model: Ranger
Engine: Going 5.0
Class: 2wd street
Thats the worst part from getting it from ford. LMC didnt have what I was looking for. However Currie Enterprises has them for 90/each, still not what I am looking for but a hell of a lot cheaper then ford. Hope the guy on the explorer forum is still making them.
Thanks for the help fella's |
Tweet
#8 | |
Year: 1993
Make: ford
Model: explorer
Engine: 4.0
Class: 4x4
Used For: mall crawling
Rep Power: 12 ![]() iTrader: (6)
Quote:
Tweet
#9 |
Year: 2005
Make: Ford
Model: Ranger Edge
Engine: 4.0L V6
Class: 4x4
Used For: trails/daily driver
Rep Power: 7 ![]() iTrader: (0)
Just run without them. Took the dust shields off front and rear on my D60's all they do is trap rocks inbetween and get beat up...
__________________
Wheeler '05 Ranger Edge SAS'd, 5.38's, D60/D60U, 38.5" TSL SX's, build thread |
Tweet
#10 |
Premium Member
Year: 97
Make: Ford
Model: Ranger Splash
Engine: 4.0 OHV
Class: JD 5.5" Stage 3
Used For: wife drives it to work
Rep Power: 8 ![]() iTrader: (0)
You do understand that they are mor ethen just DUST sheilds. At highway speeds they also assist in directing air flow over the rotors to assist in cooling.
Tweet
#11 |
Make: Ford
Class: 4x4
At highway speeds how much are you using your brakes?
The backing plates on the disc brake 8.8 are also the caliper mounts.
__________________
Tweet
#12 |
Premium Member
Year: 1993
Make: Ford
Model: Ranger
Engine: 4.0L
Class: 4x4
Used For: Weekend Warrior
Rep Power: 21 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (8)
There's a caliper mount AND a stamped backing plate. What exactly are you looking for?
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
