Serving 1984-1990 Ford Bronco II Owners & Enthusiasts
Home Library Bronco II's For Sale Bronco II Gallery B2C Shirts & Decals The Ranger Station
Go Back   The Ranger Station Forums > Truck Discussions > Bronco II & Explorer Specific
Notices
Bronco II & Explorer Specific Also check out our Bronco II section at the BroncoIICorral
Post New Thread Reply
Thread Tools Display Modes
Old 04-02-2012, 10:16 AM   #1
chrislang
Year: 1986
Make: Ford
Model: Bronco II
chrislang is on a distinguished road
Default Broco II "bucks and jerks"
Newbe here with 86 2.9l 5 speed.
I know you guys must have had this discussion come up, but I searched and cannot seem to find an answer.
Issue: Starts up and idles fine. When taking off it is fine, if you rev the engine up on take off. Idles fine, and will rev up fine parked in neutral. It stumbles and jerks violently upon acceleration between shifts. I just bought this, because it is in such good shape. No rust, immaculate interior.
The guy I bought it off of has tested virtually ALL of the sensors, changed both fuel pumps, drained the tank, replaced the computer, new plugs and wires.... NO CHANGE...
Temp. does not seem to matter, IE: does not start this acting up when hot, it can happen anytime. Vacuum issue,(can't find any) Timing? (set 10deg. BTDC)..Cold spark? Maybe I need to use the Motorcraft 42Cs? (not sure whats in it now)
The motor was swithed out to one with a lot less miles. The guy I bought it from wasn't sure of the year although he said it was newer.
Could it be the motor mounts?? I have a truck that acted like that when it needed motor mounts.(Runs fine in 5th gear when your accelerating) Seems to happen most when you are letting off the accelerator, then resuming acceleration.
I know you guys must have discussed this ad nauseam in the past. If so, please point me to the link.
I really like the BII and am determined to find the issue. I hope you guys can help. Any and all comments will be appreciated!!
Thanks in advance!
Chris
chrislang is offline   Reply With Quote
Old 04-02-2012, 11:04 AM   #2
85_Ranger4x4
85_Ranger4x4's Avatar
Year: 1985
Make: Ford
Model: Ranger
Engine: 5.0
Class: 4x4
Used For: A weapon of massive consumption.
85_Ranger4x4 has a brilliant future85_Ranger4x4 has a brilliant future85_Ranger4x4 has a brilliant future85_Ranger4x4 has a brilliant future85_Ranger4x4 has a brilliant future85_Ranger4x4 has a brilliant future85_Ranger4x4 has a brilliant future85_Ranger4x4 has a brilliant future85_Ranger4x4 has a brilliant future85_Ranger4x4 has a brilliant future85_Ranger4x4 has a brilliant future
Default
It is a Bronco, did you not see the bucking horse badge?
You might install a vacuum gauge in it and see what it is doing realtime as you drive it.
Probably a nonissue but you did unplug the dizzy when you set timing right?
__________________
1985 Ford Ranger Custom, 4x4, PA 3" BL, 5.0 HO wannabe, C5 Transmixer, 31 spline T/L 8.8 w/ disc brakes.
Build Thread
My Ranger is not old; no one would call her old. She has a bluff bow, lovely lines. She's a fine truck: weatherly, stiff and fast... very fast, if she's well handled. No, she's not old; she's in her prime.
85_Ranger4x4 is offline   Reply With Quote
Old 04-02-2012, 12:33 PM   #3
chrislang
Year: 1986
Make: Ford
Model: Bronco II
Default
By dizzy, do you mean the SPOUT plug? I did indeed unplug it. Does that stand for SPARK-OUT? It is not one of those typical TFI things about getting hot, then shutting off. As long as I am accelerating it seems to do ok. But in between shifts, it bucks when pressing the throttle as you release the clutch.
Thank you all for any info, as I am at a loss of ideas.......
Old 04-02-2012, 01:34 PM   #4
Danni84
Danni84's Avatar
Year: 1984, 1988
Make: Ford
Model: Ranger, Bronco II
Engine: 2.8l 104k miles & 2.9l 245k miles
Class: 4X4
Used For: Work in Progress
Danni84 is on a distinguished road
Default
"Seems to happen most when you are letting off the accelerator, then resuming acceleration"
I dont know if the 2.9 has it or not but my 2.8 did that and the EGR valve was stuck closed from carbon build up. Finally got it diagnosed after the 3rd mechanic looked at it. EGR valve and timing had it running well again.
Danni84 is offline   Reply With Quote
Old 04-02-2012, 01:41 PM   #5
85_Ranger4x4
Year: 1985
Make: Ford
Model: Ranger
Engine: 5.0
Class: 4x4
Default
Yeah, dizzy = distributor = spout plug (implied, sorry)
__________________
Build Thread
Old 04-02-2012, 01:54 PM   #6
chrislang
Year: 1986
Make: Ford
Model: Bronco II
Default
Thanks Dannie84!
I'll try that this evening or tomorrow. It can't hurt!
Old 04-04-2012, 03:59 PM   #7
tw205
Junior Member
tw205's Avatar
Year: 1985/1988/2000
Make: Ford
Model: Bronco II/Mustang LX/F-250 Superduty
Engine: None/5.0/6.8
Class: 4x4
Used For: An excuse to drink in the garage
tw205 will become famous soon enough
Default
Sounds like a faulty throttle position sensor
tw205 is offline   Reply With Quote
Old 04-04-2012, 04:33 PM   #8
shane96ranger
\----===FoMoCo===----/
shane96ranger's Avatar
Year: 1997 / 1989
Make: Ford
Model: F150 XLT / Mustang GT
Engine: 4.6 Triton / 5.0
Class: 4X4 / Hot Rod
Used For: Everything / The war on imports
shane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond repute
Default
Have you checked for play in the distributor shaft?
__________________
Click to see my 97 F-150 XLT
Click to see my 89 Mustang GT
Quote:
Originally Posted by jammert609@yahoo.com View Post
I am being told by family an friends my truck is a piece of shit
shane96ranger is offline   Reply With Quote
Old 04-25-2012, 12:45 PM   #9
tdjar
Year: 1986
Make: Ford
Model: Bronco II
tdjar is on a distinguished road
Post
I have an '86 as well and it does the same thing except it happens when I try to maintain a constant speed. Doesn't matter what gear I'm in or what speed I'm going. I haven't been able to get at this yet 'cause the input bearing went in the tranny , it is going back in this weekend, then it will be diagnosis time. I will post what I find and hopefully we can figure this out
tdjar is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2012 / 959 Media LLC / All Rights Reserved
[Legal Notices]   [Advertising/Vendors]
Also check out SSP Central for Special Service & Non-Traditional Police & Fire Vehicles
