| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| Bug Out/Survival, Overlanding & Camping Vehicles Vehicles only. Weapons, survival & camping gear are in the next forum down. |
Thread Tools | Display Modes |
#1 |
Year: 1995
Make: Mazda
Model: B2300
Engine: 2.3L
Class: 2wd
Used For: character building
Rep Power: 8 ![]() iTrader: (0)
Hi, everybody,
I moved to Washington State from upstate NY 9 months ago. I built this camper shell to transport all my stuff, half of which I promptly gave away when I got here. Now I'm going to do some inside work to it. Which is why I'm here visiting TRS, because I want to install a couple forklift batteries in series to get 12V, to power my stuff. I want to charge the batteries off the truck when I'm driving, or off a 110 outlet at a campground, etc. And when I use my "stuff", and the truck isn't running, I want the truck battery isolated from the load. All my stuff runs on dc, different voltages, and each one has a charger. I could probably use an inverter to run a strip of outlets, and plug in all the chargers: Cell phone, laptop, boom box. Plus I want a couple or three lights, and a small dc fan for my fireplace intake air. I don't know if the inverter is the best route, or should i buy a device that can put out exactly so many dc volts, and use it to feed my devices, instead of using their own chargers. So I need a book about how to do the dc system. Or knowing the key words to use, I can go look in the library for a book. Wiring DC Campers? So I built the shell in NY, 3/8" cdx plywood, 1x2 white pine studs, high grade polyurethane construction adhesive, and exterior grade star screw. I predrilled everything through the plywood. I used flat 2x4's for triangulation braces so the leading edge and the top edge of the thing, the part that hits the 80mph wind, is solid as a rock. The leading edge and the top edge of the roof both have double 2x4 headers going across, glued and screwed. On top of the plywood I put two coats of epoxy resin, and I used fiberglass cloth on all joints and corners and edges. That made it waterproof. Then I put two coats of Above Water Line marine paint on top of the resin, and did it in a sort of artsy fartsy way. Some of it looks stupid, like the hatch marks that are supposed to be a weave? And the first aid cross. Goofy. But the rest of it is okay. So on the inside there are three layers. I have three 2' x 5' panels that join up with the floor of the overcab to make one long flat floor from front to back. It's about 8'6" x 5' 0". I had my queen mattress up there, but gave it to someone. Now i use a foam pad. I'm going to build some cabinets along the two sides and the front of the bed, that will double as short tables and a couch seat. The back corner will have a space for my twig-burning cook stove, and I'll have an exhaust hood installed right over it, attached to the framing of the shell. I'm looking for a tiny woodstove for it, but will set it up for both the open fire cook stove, and if I find a woodstove, it's pipe will fit right up in there. ![]() ![]() ![]() ![]() Anyway, I've been drawing and measuring and drawing and thinking, and I'll probably buy the materials to do it tomorrow. I'll be hitting the road about March 13th, maybe sooner, for some exploration, truck camping, backpacking, and plain old camping out! I'll get some pix tomorrow, the before shot - the big empty, showing the three panels that can fit in several places. Like for a table possibly. And I'll figure out how to get a picture on here of my drawings of the layout, cross-section, construction details, etc of the cabinet/seats. The back end is 3" higher than the front now, because I had the rear leafs retempered, and I added a heavy duty leaf to each side (duh, each side). And i added new shocks in back. The front has not been retempered, and has the worn out shocks, and it sits 3" lower. I wonder how to fix that. ok, I know I'll find out here. TRS rocks. Like the Red Sox. (Born in Boston.) The shell weighs 750, and with the cabinet/seats, I think that will be 850. Last edited by auto117584; 02-24-2012 at 01:40 AM. |
Tweet
#2 |
Year: 1987/1990
Make: fords and only
Model: ranger
Rep Power: 16 ![]() ![]() iTrader: (0)
throw some over load springs on that. and it look great
__________________
1987 ranger super beast__1990 ranger
duff lift_________________2.9 to 4.0 swap dana 35 and sploder 8.8___duff 3 inch lift 302 swap_______________locked front and back cab off frame ![]() 97 ranger DD ![]() 3.0 manual every thing after market headlights 4.0 S.O.H.C swap in the works |
Tweet
#3 |
Year: 1994
Make: mazda
Model: b-3000
Engine: 3.0l
Class: 4x4
Used For: everything
Rep Power: 9 ![]() iTrader: (1)
looks good,i like how you slanted the front for aero dynamics,good job.kinda motivates me to try building one for my truck.i probably cant make mine as tall
__________________
4 inch skyjacker,3 inch body,d35 and 99 explorer 8.8 with disc brakes,33x1250-15,4.56 gears,flat black paint(removed and/or painted over ALL reflectors, homemade,cannot and will not be detected at night, spare tire carrier(made from sway bar)mounts in the bed,back off or dim your lights rear monted fog lights w/toggle switch(lol),trimmed fenders,and saving up for 35's(finally)WOOHOO!! |
Tweet
#5 |
Super Moderator
Year: '91, '85, '97
Make: ford
Model: ranger, b-II, f-150
Engine: 4.0,4.0,4.2
Class: 4x4 race, 4x4, 2wd work
Used For: 4x4 race, 4x4,2wd work
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
Looks good.
__________________
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein |
Tweet
#8 |
Year: 1995
Make: Mazda
Model: B2300
Engine: 2.3L
Class: 2wd
The truck is actually more stable on the road with the camper. Even the 18 wheelers don't push it over when I pass them. I get 18mpg at 70mph with the shell.
Tweet
#10 |
Premium Member
Year: 2000
Make: Ford
Model: Ranger
Engine: 3.0
Class: 4WD
Used For: DD
Rep Power: 21 ![]() ![]() ![]() ![]() ![]() iTrader: (1)
Heh, heh. I remember you getting broke down in some forest last year.
Good to hear you are making out OK. You got a lot of spirit! Still Bloggin? How about a link?
__________________
If at first, you don't succeed, RTFM. |
Tweet
#11 |
Year: 1993
Make: ford
Model: ranger s/c
Engine: 4.0/245 c.i.d.
Class: 4xford
Used For: gitten' it done!
Rep Power: 16 ![]() ![]() ![]() iTrader: (0)
not bad, surprized the 4 cyl can handle it. id make the back all solid, ditch the tailgate & put a traditional walk-in door.
__________________
at the corner of "walk" & "dont walk" cardomain link:--> http://www.cardomain.com/ride/3216869 1993 ranger s/c 4.0 hurst-equipped 5-spd,3.73s ,4x4, milemarker hubs, black grille guard/tube steps,summit rear diff cover with bearing load supports. 117K & still going strong. http://www.myspace.com/small_dog_trucking |
Tweet
#12 |
Super Moderator
Year: 1989
Make: Ford
Model: Bronco II
Engine: 4.0
Class: 4X4
Used For: a chicken house
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (1)
I love woodstoves in vehicles. They exist, new, but are dam expensive.
The only thing I don't like is the locks on the rear door. Some jackass might lock you in!
__________________
'83 Ranger cab, '89 B2 frame, 4.0, C5, D35/8.8, 4.10s, Lockrights. '87 Chevy crew 6.2 Banks turbodiesel TH400 GearVendors 4.10 14-bolt Detroit '96 VW Passat Tdi '00 Ford E350 15-pax Powerstroke '09 Suzuki TU250X '04 Moto Guzzi Breva http://willwills.com/ |
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
