| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| Off-Road Rangers Under Construction Share your off-road Ranger projects here so we can follow the progress. |
Thread Tools | Display Modes |
#193 |
Capt. Slow
Year: 1987
Make: Ford
Model: Ranger
Engine: 2.9 V6
Class: 4X4
Used For: Daily Driver / Off Road from time to time
Rep Power: 10 ![]() ![]() ![]() iTrader: (3)
Thats a beast of a truck. I read your build all the way though, great work!
Tweet
#194 |
Year: 1990
Make: Ford
Model: Ranger
Engine: 5.0L
Rep Power: 13 ![]() iTrader: (1)
Thank you very much, I appreciate that alot.
__________________
Dana 44, 5.0L, 1990 ranger, custom interior.... Ive got all the pieces now how do I put em together ![]() My Backyard Build Build Thead |
Tweet
#195 |
Year: 1990
Make: Ford
Model: Ranger
Engine: 5.0L
Well now that I've been driving this beast for quite some time now. Its time for something strange to break in some strange way.
I was on my way out to pick up a plow for the old red explorer, and when I started backing up to unload the crap from the back of the truck it started to make a REALLY loud knocking noise. So I look underneith to investigate and what did I find? The transmission was twisting but the engine was still! there was a huge crack accross the bellhousing, from drivers side to passengers side! ![]() ![]() ![]() ![]() So now its time to swap the internals to a new case and try again. While I am in there I am going to change up a few things about the exhaust to keep it from leaking all the time, going to shoulder the pipes so that they slide into the next one and bolt together with the flange, instead of just the flange and gasket. Any ideas what may have caused this or how to prevent it again?
__________________
Tweet
#196 |
November 2012 OTOTM Winner
Year: 1990
Make: ford
Model: ranger
Engine: 5.0
Class: 4x4 extreme
Used For: getting away from the kids
Rep Power: 5 ![]() iTrader: (0)
Sweet build pretty similar to mine. Ive seen the trannys break like that when the crossmember or motor mounts arnt mounted in a similar manner. Like stock rubber motor mounts and stiff poly tranny mount transmission mount. Good luck!
__________________
90 ranger 5.0 dana 44 60 rear c4 203/20 cases on 4d's |
Tweet
#197 |
Capt. Slow
Year: 1987
Make: Ford
Model: Ranger
Engine: 2.9 V6
Class: 4X4
Wow that's a huge break! What's next? Another auto or will you swap for a 5 spd?
__________________
-1987 Ranger 4x4- 3" Body Lift, 2.9 V6, A4LD auto, Manual Hubs, Dynomax Super Turbo Exhaust, 30x9.5R15 A/T, 15x8 Cragar Soft 8 Wheels |
Tweet
#198 | |
Year: 1990
Make: Ford
Model: Ranger
Engine: 5.0L
Quote:
Another auto. I just happen to have another AOD in the garage that I bought for the throttle valve cable and brackets for $60. Im glad I held onto it instead of scrap it. If it breaks again I will go to a mazda trans from an f-150.
__________________
Tweet
#199 |
Year: 1990
Make: Ford
Model: Ranger
Engine: 5.0L
Broke another 2 bell housings and the only thing left to blame now is the driveshaft.
So. Now that the ranger has sufficiently pissed me off... Its time to gut it! I never thought that I would be able to do it. But I think I am going to break it down and tear it apart after all that work! I picked up a 2003 Sport Trac that I am going to swap the axles and such into. I am undecided if I want to swap the 5.0 into it also. Or get the ODB2 system and engine from an explorer. For now I need to clean the new truck and get the tree branch dent out of the roof.
__________________
Tweet
#200 |
Year: 1990
Make: Ford
Model: Ranger
Engine: 5.0L
Ranger replacement... Sport Trac Stealth Edition
![]() haha and this is the day after i picked it up... ![]() tags: matte black sport trac, vinyl wrap, flat black wrap
__________________
Tweet
#201 |
Year: 1990
Make: Ford
Model: Ranger
Engine: 5.0L
If anyone is still watching this... the ranger replacement is almost fully wrapped in matte black vinyl. Its looking great!
__________________
Tweet
#202 |
Capt. Slow
Year: 1987
Make: Ford
Model: Ranger
Engine: 2.9 V6
Class: 4X4
That looks really good! I think that's the 1st time that i've ever seen that done on a Sport Trac.
Did you spray it yourself?
__________________
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
