Serving Ford Ranger, Bronco II, Explorer & Mazda B-Series Owners Since 1999
Home Forums Info - Technical Info - Other TRS News Photo Galleries Shirts & Decals Parts Store Classifieds
Go Back   The Ranger Station Forums > Styling & Electrical > Interior
Notices
Interior Seats, carpet, consoles and interior panels. Speaker/sub enclosures go in the Audio & Video forum. Forum sponsored by Aqua Graphix
Post New Thread Reply
Thread Tools Display Modes
Old 04-06-2008, 10:24 AM   #1
ralf
Year: 1998
Make: FORD
Model: Ranger XLT
ralf is on a distinguished road
Default Window wobble
The window on my driver's side has a little bit of play forweward and backward. When I roll the window down it causes it to wobble bad and then vibrate and jump as it goes down. I took the panel off and greased everything I could see, but there doesn't seem to be a visible problem. The window is only attached at two places that are very close to each other so I don't see how it could have much stability, anyone else experience this. I checked the passenger sid eand it appears to have the same play, but works fine.
1998 Ranger XLT 4.0L
ralf is offline   Reply With Quote
Old 04-06-2008, 10:48 PM   #2
TheDanger2801
Junior Member
Year: 1998
Make: Ford
Model: Ranger XTL
TheDanger2801 is on a distinguished road
Default
Same Problem in the same exact truck haha. I took the door panel off and couldn't see anything wrong so i just sucked it up and got used to it.
__________________
98 Ext Cab 4x4
BFG A/Ts
System One Ladder Rack and Tool Box
4 KC Daylighters
Flowmaster 40
Kenwood head, 3 way Pioneers all-round, Lightning Amp, dual 8 inch Oz subs in custom boxes.
TheDanger2801 is offline   Reply With Quote
Old 04-06-2008, 11:45 PM   #3
Loanranger
Loanranger's Avatar
Year: 1989/ 1972
Make: Ford/ Fordzuki
Model: Ranger SC XLT/ Mutt?
Engine: 2.9/2.3
Class: 4x4/Custom
Used For: Daily driver/Jeep Recovery
Loanranger is on a distinguished road
Default
It sounds to me like the rubber window run channel is dry, and grabbing the window as it goes up and down. The main problem is your regulator is probably worn, but you can make it glide up and down easier by lubing up the run channel. Just use some rubber reconditioner, or if you can't find any, use lithium grease in a spray can. A little bit will go a long way.
__________________
Sold the ranger
Fordzuki, 72' Suzuki LJ20, w/ '97 2.3 and M50d, locked, geared, linked rear, 34x10.50s
Daily driver, '86 Suzuki Samurai, stock other than geared t-case and a rear lockright.
Loanranger is offline   Reply With Quote
Old 04-07-2008, 09:30 AM   #4
rickcdewitt
rickcdewitt's Avatar
Year: 1991
Make: ford
Model: ranger-needs more lift
Engine: 4-0 swap
Class: 4x4
Used For: work and play
rickcdewitt is on a distinguished road
Default
you should be able to adjust one of the tracks closer in to stop the wobble.
__________________
4.10's, 33's, duff stage 3 w/4" coils, cb,cowl snorkle, homemade high clearance d-ring bumpers,bobbed bed,8.8
My bobtail beater
Quote:
Originally Posted by fastpakr
Try to stick to posting about trucks, unless you can figure out a way to control yourself.
rickcdewitt is offline   Reply With Quote
Old 08-25-2008, 08:22 PM   #5
cNo7
cNo7's Avatar
Year: 1999
Make: Ford
Model: Ranger
cNo7 is on a distinguished road
Default
A non-silicone rubber care sprayable product will help...along with some white silicone grease sprayed onto the regulator track
__________________
1999 Ranger XLT Supercab 4x4
cNo7 is offline   Reply With Quote
Old 09-01-2008, 04:41 PM   #6
thepretzelman
thepretzelman's Avatar
Year: 2000
Make: Ford
Model: Ranger
Engine: 3.0L
Class: 4x4
thepretzelman is on a distinguished road
Default
I have the same problem in my 2000
__________________
2000 Ranger XLT 3.0L 4x4
3in. PA Body Lift
Torsion Bar Crank
285/75/16 Pro Comp Mud Terrains
thepretzelman is offline   Reply With Quote
Old 11-29-2008, 02:17 AM   #7
redtruck
redtruck's Avatar
Year: 1998
Make: Ford
Model: Ranger xlt
Engine: 4.0
Class: 2WD
redtruck is on a distinguished road
Default Know that problem well
I have a 1998 Ranger too. My Dad bought it new and it did the same thing when it was less then a year old. Still being under warrenty it was taken back to the dealer several times to fix the problem. After a call to ford and a trip to a differant dealer, all the inner "guts" (track, window motor, regulator ect..) were replaced. Mom gave me the truck when Dad passed 2 years ago, and the windows have never had the problem since that last fix was done almost 10 years ago. I know the first dealer had tried adjusting the track several times, and from what I recall replaced the parts that guide the window in the track with no success. I think it actually was defective tracks that was causeing the problem.
redtruck is offline   Reply With Quote
Old 11-29-2008, 06:19 PM   #8
4x4junkie
Mall-Rated
4x4junkie's Avatar
Year: 1990,1994
Make: Ford
Model: Bronco II, Ranger
Engine: 2.9L, 4.0L
Used For: Crawling over things
4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all
Default
My 1990 was doing that (rattling & jumping while rolling the window down).
The fix was greasing the metal center channel that the regulator bracket (attached to the glass) slides up & down in.
__________________
'90 Bronco II XLT
5" lift (Skyjacker Jeep coils), D35 & 8.8" w/5.13s (locked), 1354 dual T-case, 35x12.50s
'94 Ranger XLT
6" Skyjacker, ARB D44 front, Detroit 8.8" rear, Atlas 4.3, 33s
4x4junkie is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2012 / 959 Media LLC / All Rights Reserved
[Legal Notices]   [Advertising/Vendors]
Also check out SSP Central for Special Service & Non-Traditional Police & Fire Vehicles
