Serving Ford Ranger, Bronco II, Explorer & Mazda B-Series Owners Since 1999
Home Forums Info - Technical Info - Other TRS News Photo Galleries Shirts & Decals Parts Store Classifieds
Go Back   The Ranger Station Forums > Truck Discussions > General Discussions
Notices
General Discussions This forum is for general discussions. Place posts that don't fit in any other forums here.
Post New Thread Reply
Thread Tools Display Modes
Old 11-12-2011, 11:35 PM   #1
lulanda21
Year: 1993
Make: ford
Model: Ranger XLT 4x4
Engine: 4.0
Used For: Everyday driver
lulanda21 is on a distinguished road
Default 4.0 Cold Air Intake
Ive been trying to install a cold air intake on my 4.0 ranger, Its a el cheapo from auto zone but I have a nice filter.
Anyways, I hooked everything up (truck ran great before) and it was hard to start, and when it started it would idle rough and shut off, but I can unplug the MAF and it idles fine. One of my buddies said that I prolly have a leak so I took it back off and checked everything, and tightend it again and it still runs like crap, It does smooth out a bit when it warms up though....
Any Ides?
MAF, TPS, and the Idle can thingy on the side of the intake are all new also.
The truck has also been tuned up recently.
lulanda21 is offline   Reply With Quote
Old 11-12-2011, 11:55 PM   #2
Sasquatch_Ryda
Coast Mountain Crawlers
Sasquatch_Ryda's Avatar
Year: 1991/1997/2008
Make: Ford
Model: Ranger/Ranger/SuperDuty
Engine: 4.0L/3.0L/6.4L
Class: 4x4
Used For: Play toy/Daily Driver/Grocery Getter
Sasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to behold
Send a message via MSN to Sasquatch_Ryda
Default
Is this an oiled filter? If so the oil from it probably contaminated the MAF wire.
__________________
http://www.coastmountaincrawlers.com
1991 Ranger - one tons, 3 link, air shocks and 40's
1997 Ranger - reg cab flare side, 3.0L, M5OD-R1, 4x4, 4.56 gears, 6" lift, 33" MT's.
2008 F350 - 6.4L Powerstoke Diesel, 35x12.50R18 Procomp Xtreem AT's on 18x9 Incubus Crushers, AFE DPF/DOC Delete pipe, H&S XRT Pro tuner, AFE Stage 2 intake
1967 Mustang Coupe - 289, c4, pretty much stock
Sasquatch_Ryda is offline   Reply With Quote
Old 11-13-2011, 12:10 AM   #3
lulanda21
Year: 1993
Make: ford
Engine: 4.0
Default
No oil.
Old 11-13-2011, 08:16 AM   #4
straycat
Premium Member
straycat's Avatar
Year: 99, 02 and 06
Make: Ford /Jeeps/Etc
Model: 99 Ranger 4.0L 2wd 33x12.5 KO tires. Grand Cherokee 4x4 4.0L Wrangler X 5.7 Hemi 87 Samurai 4x4
Used For: DD and trail rides
straycat has much to be proud ofstraycat has much to be proud ofstraycat has much to be proud ofstraycat has much to be proud ofstraycat has much to be proud ofstraycat has much to be proud ofstraycat has much to be proud ofstraycat has much to be proud ofstraycat has much to be proud of
Default
Many years back I add an AEM polished air tube and dry cone filter. I had been using a K&N oiled cone setup for many years. I never had a problem with any of the setups. I got tired of having to re-oil the K&N every once in awhile so I thought it was time to swap it for a dryflow filter. Maybe you pulled off a wire somewhere or a vacumm hose and don't know it? Recheck everything and if not, then put it back to stock and see what happens. I never heard of anybody having issues swapping to a tube intack and different filter before.
__________________
Straycat
99 Ranger XLT 4 door Supercab lifted 2wd
33x12.5x15 KO's on 15x8 AR polished rims
Spare 33 KO mounted flat in bed/custom bed extender
straycat is offline   Reply With Quote
Old 11-13-2011, 08:30 AM   #5
shane96ranger
\----===FoMoCo===----/
shane96ranger's Avatar
Year: 1997 / 1989
Make: Ford
Model: F150 XLT / Mustang GT
Engine: 4.6 Triton / 5.0
Class: 4X4 / Hot Rod
Used For: Everything / The war on imports
shane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond repute
Default
That's kind of what I was wondering Stray. Did you reconnect the breather that goes to the oil filler neck? And if so, is it AFTER the MAF? Ive seen a reputable shop from here install that pipe prior to the MAF on a guy at work's Mustang. After he and the shop couldn't figure out why it was running like ass and messing up MAF's, I looked at it and found that. Problem solved.
__________________
Click to see my 97 F-150 XLT
Click to see my 89 Mustang GT
Quote:
Originally Posted by jammert609@yahoo.com View Post
I am being told by family an friends my truck is a piece of shit
shane96ranger is offline   Reply With Quote
Old 11-13-2011, 08:33 AM   #6
Tracked and Locked
Asteroids Champion
adsm08's Avatar
Year: 1987
Make: Ford
Model: Ranger XLT
Engine: What engine?
Class: 4x4
Used For: Elevenses
adsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond repute
Send a message via AIM to adsm08
Default
Put your factory setup back on, just for fun, fire it up, and see if it runs right again.
If it does, try resetting the computer's memory and try again with the new setup. You altered air flow when you installed the new system and the computer may not have figured it out yet.
__________________
Project: Hillbilly Deluxe
Project: Amazing Grace
Project: 12-Volt Sandwich
Quote:
Originally Posted by Mark_88 View Post
Question: "What year is your truck"?
My Answer: "What part"?
Quote:
Originally Posted by John Adams
Our Constitution was made only for a moral and religious people. It is wholly inadequate to the government of any other.
HELP REPEAL OBAMACARE
Looking for 95-98 manual trans pedal bracket. Conducting an experiment for the betterment of all Ranger-kind.
adsm08 is offline   Reply With Quote
Old 11-13-2011, 10:05 PM   #7
lulanda21
Year: 1993
Make: ford
Engine: 4.0
Default
Everyhting looks good, I checked all wires and only one hose going on it and thats the hose for + crank case pressure. When i put old setup back on it runs fine.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2012 / 959 Media LLC / All Rights Reserved
[Legal Notices]   [Advertising/Vendors]
Also check out SSP Central for Special Service & Non-Traditional Police & Fire Vehicles
