85_Ranger4x4
Wallers in rivers
💻 TRS Socials
- Aug 7, 2007
- Frankfort
- State - Country
- IA- USA
- Manual
I should have started one of these a long time ago, so there is some catching up to do.
In late August 2000 for my high school vehicle, I don't remember what day it was but I got insurance for it on 9-11-00 (I remember being shocked right after 9/11 when I went to put the new card in it)
Just like this but with a black grille and an aluminum toolbox that has came and went several times since:
I joined here for the first time in 2002, when my first A4LD died. I got a parts truck for the trans and that is where I got the chrome grille.
In 2003 I made a grille guard from some salvaged steel.
In 2006 I added a 3" bodylift. In 2007 I picked up a set of 235/75-15Dunlop Mud Rovers (same size as the street tires it came with) I don't have a pic of it with the regular tires, take my word for it... it looked stupid. The front bumper bracket followed shortly thereafter.
In 2008 I picked up a much better looking set of rims at a swap meet for $75.
Later in 2009 I picked up rollbar for $20 off of craigslist
Along the way I had been gather things to replace the dying 2.8 with something that if it didn't beat 10mpg... justified it. I got sidetracked on an engine that needed a ton of work, eventually I found a good one.
Swap thread:
http://www.therangerstation.com/forums/showthread.php?t=61372&page=3
I finished that somewhere around March (it is in that thread somewheres)
Final specs
1987 non-HO shortblock
Weiand Stealth intake manifold
Edelbrock 1403 500 CFM carb
Duraspark ignition
Hedman 88400 headers
2" true duals with glasspacks, routed between the frame rails and coming down between the bed and frame in front of the rear bumper.
M5ODR2 5-speed and twin stick NP-205 t-case
Initially after the swap it looked like this:
Now the engine bay looks like this:
A very subtle hint that it isn't a normal Ranger, the V8 badge off of the back of a 2002+ Explorer in leu of the V6 badges that it should have had (but didn't
While I had the interior gutted I installed the interior out of two different '93 Explorers, the console out of one and the seats out of another.
As it sits now:
Photobucket has my build thread in shambles with no easy way to fix it. I am creating albums on Flickr to get pics back out there. I bought my 302 late 2010 and worked it over that fall before installing it in early 2011. 8.8 Swap took place that summer. Explorer FEAD upgrade happened summer of 2012. Bunch of little stuff in between but that should somewhat help you get words to go with pics. I am working on getting it somewhat indexed. If all else fails PM me.
Prepping the 302 preswap (Tri-Y's didn't fit so they were not used)
https://flic.kr/s/aHsm1L5zJT
V8 Swap
https://www.flickr.com/gp/152407235@N06/7013b1
1996 Explorer 8.8 Swap
https://www.flickr.com/gp/152407235@N06/646ktj
V8 Swap (initial) - Early 2011
Instrument Cluster Restore - Late 2016
Battery Tray Swap - Early 2017
Rear Sway Bar Install - Summer 2020
Rear Bumper Build - Summer 2020
Swap thread:
I am in the process if changing my engine over to the Explorer FEAD from the small micro V belted Crown Vic setup.
First off I can only find the 90 degree water outlet for a Mustang, is there any reason this won't work for an Explorer too since nobody calls for it fitting? I didn't think to grab one at the JY and figured since the CV 45 degree one was $10 I would just get a new one rather than deal with it... no dice.
http://www.oreillyauto.com/site/c/detail/MRG0/9713.oap?keyword=9713
As I am taking stuff and comparing to the Explorer stuff I get to wondering, I hold the donar...
- 85_Ranger4x4
- Forum: Engine Swaps
What is the minimum safe distance between the valves and pistons in a 5.0?
I have searched and searched the web, one guy said .1 for an automatic (which mine is) but I didn't know if somebody had it in a book or something rather than some random guy on the internet pulling a number out of an aft orfice.
- 85_Ranger4x4
Final specs
Duraspark ignition
As it sits now:
V8 Swap
I know the 351W is wider and taller. Anyone know how much taller it is at the exhaust? Any deeper between the oil pan and the engine mounts? The exhaust is tight to the floor now on the PS side and the oil pan is tight to the crossmember... I don't have a ton of wiggle room there.
Any 351W header pics (especially Hedman 88400's) would be much appreciated too.
- 85_Ranger4x4
- 85_Ranger4x4
- Forum: Charging, Misc Electrical & Gauges
First gen battery trays generally don't age well, this is how I fixed mine.
I started out with this beauty.
I got all that removed and cleaned up.
Then I hit the JY to find something that might work. I knew second gens had the same dinky battery tray but they were riveted in so I looked at fullsizes. Bullnose Fords had the tray made into the inner fender so that was no dice but I did find brick noses (87-91) had a tray that had...
- 85_Ranger4x4
For the most part mine works great, sometimes it surges though. On our trip to Ohio it seemed impact related, hit a big bump and surgy surgy until I pulled the vacuum line off the servo. One time I hit a big bump and it got to surging and then I hit another railroad crossing and it came out of it. It only did it thru Illinois on the way out (they have a crappy highway), across Iowa, Indiana and Ohio and then the whole way home it didn't miss a beat. It did it again after it sat all winter... until I pulled the vacuum line off the servo and it has worked perfect for two days now...
- 85_Ranger4x4
My Ranger originally had something like a 45A alternator, it now has a 130A Explorer alternator. I have added a lot of stuff to it over the years, all of which runs off the battery side of the starter relay.
I will be doubling the number of efans in the future and someday hope to add a winch.
At what point is the factory wiring not going to be enough? What is the best way to go about fixing it? According to the EVTM it T's with one going to the battery and the other going to the fuse panel.
- 85_Ranger4x4
