| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#25 |
Year: 1989
Make: Ford
Model: Ranger
Engine: 2.9
Class: 4X4
Used For: Off road / daily driver / Haulin Dirt Bikes
Rep Power: 10 ![]() iTrader: (0)
the air temp sensor tested ok, so I cleaned it up and did a little repair work on the connector. the female side of the contacts appeard to be a bit streched out so the sensor might have been losing connection intermittently. I pryed everything back into shape with a small screw driver and apllied some dyelectric grease before plugging the sensor back in, and haven't had a problem since (roughly a week has passed).
If the problem returns I'll keep posting, but hopefully I have it fixed. and hopefully this info helps some of you that might have similar issues.
__________________
http://www.therangerstation.com/foru...ad.php?t=66814 |
Tweet
#26 |
I Wanna Go Fast!!!!
Year: 86/03
Make: Ford
Model: Ranger/F250
Engine: 2.9/6.0
Class: 4x4s
Used For: Daily Driver/Beater/Toy
Rep Power: 16 ![]() ![]() iTrader: (9)
is it still running alright???
__________________
86 Ranger 4X4 D28 8.8 BW1350M, 33s Build Thread WTB: 6'' Skyjacker Brackets and EB Coil Springs PM ME |
Tweet
#27 |
Year: 1989
Make: Ford
Model: Ranger
Engine: 2.9
Class: 4X4
running perfect since my last post.
__________________
Tweet
#28 |
Junior Member
Year: 1989
Make: Ford
Model: Bronco 2 2.9L
Engine: 2.9L
Class: 4x4
Used For: DD
Rep Power: 5 ![]() iTrader: (0)
I had the same thing happen twice in my '88 Ranger 2.9.
First time the fuel pump went about 6 weeks later, the second it was my alternator diodes were fried. As I understand it, it was messing with the computer by allowing AC for periods, rather than DC? Anyways, on a hunch I disconnected the ground while while idling and my truck died. Replaced it and two years later still have no troubles! Good Luck! |
Tweet
#29 |
Junior Member
Year: 1987
Make: Ford
Model: Ranger 4x4 Supercab
Engine: 2.9
Class: 4x4
Used For: Camping,Hunting,Firewood, Hay
Rep Power: 9 ![]() iTrader: (0)
Did you ever find the cure for the "Jerking" ? Was it the coil ? My 87 has been giving me fits doing it. I'm afraid to take it out of town lately.........thanks
Tweet
#30 |
Year: 1988
Make: Ford
Model: Ranger
Engine: 2.9 liter
Class: 2WD
Used For: daly driver
Rep Power: 0 ![]() iTrader: (0)
Had the same problem, First the guy I bought my 1988 ranger form bypassed the inertia switch and made a bad connetion with the 2 wires. Then when that was fixed it started again, mainly when I was on the expressway. It would totaly cut out like lack of fuel, sometimes I could feather the gas pedal and it would keep it going. other times I would push in the clutch to try and restart it while moving and the starter would grind. Well I replace the electric fuel pump & sending untit and haven't had a problem since. If the fuel pump gets to hot it will cut out or if the fuel gets to low and have to work harder it could cut out also. Does your idiot lights come on when it cuts out???
Tweet
#31 |
Junior Member
Year: 1987
Make: Ford
Engine: 2.9
Class: 4x4
Did you ever get the jerking fixed ? My 87 is doing it less after cleaning and re-setting computer, but still does it whenit warms up. I'm afraid to take it out of town or highway speeds.........
__________________
"Never approach a Bull from the front, a Horse from the rear, or a Fool from any direction"
Tweet
#32 |
Junior Member
Year: 1989
Make: Ford
Engine: 2.9L
Class: 4x4
Used For: DD
Y'know, I had EXACTLY the same problem in my Ranger on the highway, so brief I almsot thought it was my imagination. Traded to a Bronco2 for family size and you know what else? I moved the alternator over because I had just redone the brushes. After a couple of weeks the Bronco 2 did the same thing! When I ran the engine and disconnected the battery, my truck died- bad diodes. I put in a whole new alternator and have had two years with no recurrence.....my poor Ranger got crushed at the wreckers for that oversight
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
