2004 seats
jdunlop77
im sure theres threads on this somewhere but im looking and need an answer quick, i can get some 2004 seats 60/40 real cheap and need new ones for my 93. does anybody know if id be able to put the 04 seats on my 93 tracks and get these seats in fairly easy? i gotta let them know by tonight if i want the new seats so im hoping someone will help thanks
you can install the '04 seats without replacing the tracks....just make sure that each truck has the same cab...if the cabs are different then you will have to use the '93 tracks....4 bolts hold each seat on...
The cabs are actually different on the 93 and the 04. So I am not sure about the seat tracks matching the floor. But you can however do some cutting and reweld the 04 seats to your stock seat tracks if need be.
Why not ask him if you can test fit them before buying them ?
And if are in dier need of seats, I have a set of 60/40 out of my 05. If you can not get the seats you are trying to buy.
thanks for the input, i think ill find a way to get them in. hes liek an hour drive away so if im going that far i want to make sure ill be going home with them or else i would test fit. but if nothing works out i sent you (bluovaldude) a pm about your seats.
the floor pans are NOT different.....
