Performance chip
POSrangerlover
Dover, DE
For a few months now I have been interested in getting a performance chip through James Duff. They usually run about 300 bucks. Rescently I was looking online and I found some on Ebay for around 30 bucks. Some of the names were Pro Choice ans Jex. Both had the same advertisements as the JD chips. I tried to look online to see if I could find any background on these companies. You know if I can get the same results for one tenth the cost im all for it. Let me know if these are worth buying or whether I should just get the JD one. Thanks for all your help in advance.
i would guess more than likely not. most of the chips on ebay are junk and dont do anything. i would go with jet or another type power programmer for the same money it gives you more settings
Most likeley it is just a resistor that tells your motor to dump in more fuel by making it think it needs to run in 'Rich' mode...
Won't help you at all sorry man
jet added a little bit of pick up to mine im not real familair with JD. but if i was to do it over again i would go with a full programer from jet or hyper-tech
What about the superchips programmer? Has anyone used this at all?
they are pretty much the same as hypertech and jet progammers all good adds for a few more ponies. and tunable settings
I was actually looking up bama yesterday. I dont know if anyone else on the site has used them?
