8.8 Axle tag decode help on 88 ranger XLT
Sighman
04/2011 & 04/2014 MTOTM Winner
MTOTM Winner
Canton, TX
Here's the deal, I have searched every where and am finding conflicting info.
88 Ranger XLT axle tag reads as follows
A S3980 - -
3 4575 8B01
I "think" its a 8.8 but cannot for the life of me decode the rest of the tag!!!
8.8 Didn't exist in rangers until the 4.0 came about. It's an open 7.5 with 3.45 gears.
Thanks! Time to look for another rear end then
Its a 7.5" axle with 3.45 gearing.
3 4575 8B01
that 3_45 means its got a 3.45 gear ratio and since there is a space its an open diff where as if it said 3L45 it would be a 3.45 ratio with limited slip. And the 75 right after that means 7.5" axle.
For example I have a 7.5" with 3.73 gearing non limited slip. the code would read 3 7375
and I just picked up an 8.8 with 3.73 gearing and limited slip... 3L7388
Its making sense now, thank you guys, this should help when I go hit pick n pull this weekend!
Sweet, new axle is in and made a world of difference, locked and sitting on 4.10's
"Sighman",
Everything you ever wanted to know or didn't about the Axle tag codes is in every BII/Ranger (including the VIN breakdown, which also states which gears are in the axles) Chilton's manual.:icon_cheers:
