BUCKING ranger
beater ranger
Well the cylinder head is on and the truck runs for the most part. when driving trying to pick up speed, unless done very delicately, the engine falls flat on its face and acts like it doesnt want to start after it stalls. Ive been over it twice and everything is hooked up and hooked up right. wondering which sensors are the most likely culprits or if there might be another trick for diagnosing this problem that you fellow ranger people have come up with. I really need to have this truck finished and running so I would really appreciate some insight here, thanks
Unplug the MAF on the intake, if thats makes it a little better your problem is either o2 sensor or the MAF itself. Otherwise, check your timing, and tps.
I guess I should have mentioned that this is a D I S engine. when i unpluged the maf sensor, the idle went down a little bit. when i open the throttle, the motor tries to die, but if I take it up slow sitting in neutral it seems ok. Hope this helps point the way, thanks again
I'm thinking of checking the fuel lines as they were disconnected when the head came out. playing it over and over in my head, it seems to fit with whats happening as before the fix, the engine ran as good as it could ... with a burnt exhaust valve. I would think that the lines are not interchangeable, but i cant swear to it as i just slid under the truck and reattached them without giving it much thought. Well, here goes nothing
Well, the fuel lines are not interchangeable, which is what i would expect so thats not it. Now the truck wont even start and it was running well yesterday, at an idle anyway. now the motor kicks violently a couple of times and quits. this really sucks:icon_confused::pissedoff:
Did you plug the maf back in? Clean your IAC and TPS, EGR and anything else you can think of. Check your trouble shooting guide in our tech section up top.
how is your fuel pressure? one of you fuel pumps could have died (if it has the duel pumps) or it could be the internal fuel strainer? they do clog up causing the motor to not get enough gas.
Appreciate the input and will check the aforementioned items. Im just really getting stressed about this thing cause as stated previously, it ran reasonable before the head came off, well, as reasonable as an engine with a burnt valve can run. really puzzled as to what could have happened.:icon_confused: thanks again for input. Also looking for testing procedures for whatever components I can test in the electronics area of the truck
