90' BII Rebuild----->> Build-up
marcehboy
Maine
1990
It all started when a kid at my school told me he picked up a bronco 2 last spring. This fall he was in my math class and told me he totaled it over the summer. We got to dealing and I ended up getting it in my yard for $100. Its got the stock 2.9 with twin sticks and manuel hubs and it all works!
How it was when I bought it. (sad sight)
Then came the donor truck 89' 2.9 2wd auto. No it wasnt cut up or dented when I picked it up. It was owned by and old man who just painted it. He was driving it and said it just stopped and wouldnt go into drive or reverse without stalling. The transmission shop told him the torque converter was locked up. I paid $250 for it and when I got it home I held it wide open and nuetral dropped into drive. She drove off the trailer and I hammered on it around my yard for the rest of the weekend. there was snow on the ground and the bald 14s were cuting it so i hacked the quarters and threw some 33s on there.
Tore the inners off the bronco
The frame horns on the bronco were all twisted up so off they went and on goes the ranger ones. got them all tacked up and then had to patch the bodymounts.
All painted up
Test fit. I have since painted the core support and inner fenders semi gloss black.
Put the 33s on to check clearance with no lift. Yeah gunna need more! I have a 2inch bl from james duff and new duff body mounts going in. The picture the rear tire isnt bolted up. after I took the picture i bolted it on and let the jack down it was a hair from the fender.
Taken today. Hung the fenders on and hood. nothing bolted. The front clip isnt even bolted or welded yet. Hoping to do some of that tomorrow.
Thanks taking a little while since im only 16, got to school full time and work part time and on top of that have to share the garage with my dad.
Started back up on it again. :D
and...
Can you guess whats happening next?
I've gotta redo the front on mine too. It doesn't look fun. But its a blast w the 4.0
ahh 4.0 ooohhh I need one the 2.9 makes some pretty awfull lifter noises
i cant believe you scraped that !!!!
Didn't realize that u were scrapping the B2. pics loaded slow. Why did u scrap it, was the body that bad?
The body was... toast. the pass rear was gone. behind the doors where gone. where the wheel wel met the floor in the rear was seperating because the body mount supports and ribbing was rotted off. it was wayyy to rusty for me. It was comparable to copykat's before he fixed his. So now shes getting the ranger cab and shortbed, possibly flatbed/tube bed
Guess that makes sense. Every B2 I've found down here are pretty much rust free. My blue one has a couple of spots, but tan is clean
i cant wait to see this im thinking of doing the same thing. take lots of pics!
o i couldnt tell it was rusted out... im not used to rusty vehicles either... keep them build pics comin...:headbang:
Today I pulled the tranny and transfer case out to change the flywheel gear which is stripped. also pulled the sway bars off. Tomarrows plan is to steam clean the frame and paint some of it, maybe sandblast it first though. I have a 2 inch body lift for it and a 4 inch suspension on its way in the mail. I plan on running a mixed matched f150/bronco/ranger leaf pack. looking for it to be fexy but level wwith the front. Also if you look in one of the first pictures you can see a big whole infront of left rear wheel..... northeastern rust...
More pictures of the cab...
Tranny out
Bad pic.. but the trans tag.. not the one i was hoping to see but well see how she holds up.
New ring gear on!
2.9 and chassis
