'02 3.0 A/c On = Rough Idle
J.HYATT
Hi all...
I've got 2002 Ford Ranger Ext. Cab 3.0 v6 automatic. If you put it in gear and turn on the a/c the engine lopes / idles badly. Whenever the compressor kicks in, it drops to 500rpm and tries to cut off. If AC is off, it idles fine.
Any Ideas???
Problem #2: Runs great down the road until you give it gas to down shift while going up hill. It will down shift but it kicks in and out like it's starving for fuel. Fuel Pump??? Filter?
Any info greatly appreciated.
Thanks,
newbie...........
BTW
Scan Tool shows no codes.
Check your Idle Speed Motor. It's two bolts mounted on the top of your throttle body. just clean it out with some gum-cutter. Clean your throttle body while you are there. Also when is the last time you did a complete tune-up, including plugs, wires, pcv valve, fuel filter,air filter?
Thanks. I'll give it a try. As for tune up I'm sure its due - just bought it. I got a good enough deal on it to put a little extra in it if needed.
Well I cleaned it and it seemed to help .... for a minute. So I replaced it, Still does the same thing. It won't do it when it first starts up and the idle is higher. What else would affect idle speed with ac on? Would an over charge on the ac system cause it?
Check your throttle position sensor (TPS). It is strictly a driver input sensor, and affects the fuel injector pulse, something like 500% override, and well if you do stomp on the gas and it's not working properly, it'll basically seem to bog out.
Thanks for the tip. So far, I've replaced the IAC Valve, and the TPS. Neither have fixed the a/c Idle issue. I've also cleaned the MAF. This one's got me stumped.
As for the problem cutting in and out at highway speeds, it's getting worse, so I think it's almost got to be fuel pump/ fuel filter.
Any further idea's on the a/c idle issue. Is it possible to just dial up the idle a few hundred rpm?
Have you checked for a binding A/C compressor? It may just be on it's way out. It'd put a load on the engine. Unplug the A/C compressor and see if it makes the difference. BTW, new parts can be DOA. Do you have a manual and multi-meter? I'd actually check the sensors.
Yea I thought about the TCC. But it down-shifts smoothly and then starts cutting out. Just to be sure, I thew it into neutral and revved it. With out fail, it will cut out at 3100 rpm. I put a fuel pressure gauge and revved it up and the pressure would drop slightly at the same instant it started cutting out. It never dropped below 50psi. I think that's more than sufficient on a flex fuel. If someone doesn't agree please let me know. It would be a releif to know that it's just the fuel pump. I know they're in the tank and it sucks a little to change em, but I'm tired of trouble shooting.
I'm afraid the a/c - idle issue is most likely what was mentioned by Ranger44.
Um, the spec on my 98 is around 70psi.
I can understand why youre tired of troubleshooting.....and you should consider a solid diagnostic by a good dealership. Ends up being CHEAPER than throwing parts at a vehicle.
If you think it might be due of r atune-up then i would do one before you spend more money to have a dealership or personal garage diagnose it. Replace the spark plugs, wires, fuel filter, air filter and pcv valve.
So far:
IAC, TPS, MAF, Plugs, Wires, PCV, Fuel Filter. Somewhere in all of that the miss at 3000+ RPM became intermittent rather than constant. I'm starting to wonder about injectors now. Is Sea Foam Recommended??? I've heard some swear by it and other say it causes more problems plugging up injectors with all the crap it cleans out. What say you fellow ranger freaks.
Well, I'd find the actual psi that should be at your fuel rail. If it's 50psi and should be above 60, then this would be a problem. Do you have a Haynes/Chilton service manual?
As for fuel injectors, I think that a fuel injector flush should be part of routine matainece. I would actually buy an injector flusher or take it to a shop. Make sure they don't do an injector flush and put it into a vaccum line. Many shops actually advertise an injector flush when it really an upper inatke mainifold flush. How does the flush reach the injectors going through a vaccum line? Make sure they actually put it through the fuel rail.
Fixed Both Problems. It's Too Simple. It Was A Friggin "driver Gear Position Switch". This Was A Tow Vehicle In Neutral For About 100,000 Miles (2002 With 237k On It). The Switch Tells The Computer It's In Gear And This Dis-engages The Rev. Limiter. The Computer "thought" It Was Always In Neutral, So The Idle Wasn't Being Adjusted Properly(it Only Acted Up When It Was In Gear), And The Rev. Limiter Kept Kicking In. Thanks For All The Comments And Suggestions. Thought I'd Post This In Case Anybody Else Ran Into It.
