Cracked filler neck.
PANTERA
My fuel filler neck has a crack near the frame. Usually if I fill the tank, I'll get a small puddle of gas underneath the truck. Is there any "cheap" way to fix this? The crack is about an inch or two long.
BTW, its a 92 Ranger. Thanks.
if you cant duct it .... it
the dealer part is like 200 or 300 but you can get an aftermarket one for like $40 on ebay
Is it a step side or a fleet side truck? The filler hose is different for the two.
Replacement is fairly easy. If you have two people you can remove the bed which while sounding like overkill is the easiest way to do it. I got one from an aftermarket supplier for about 80 bucks.
