- Jan 1, 2009
- So. Cal
- 2008 & 2001
- Automatic
Just bought a 2001 Cummins 4x4, I have some questions that maybe you guys could assist with.
If I wanted to do take off the muffler, leave the resonator on, and make it side exit is there some kind of back pressure required considering it doesn't have a cat?
I have a little play in the wheel, kinda delays the steering a bit. What would that be a problem of tie rods, steering box, or just steering column? How hard would it be to replace bearings myself?
What could be the problem of the cruise control now working, a fuse, a vacuum line, the steering column being f*^ked up?
Should I mix 2 stroke with No.2? It being more of a hassle is it worth doing it in the long run i.e. saving $ on injectors? What ratio should I mix it?
In the long end what would be a decent transmission or aftermarket parts added to stock transmission that would be able to haul and take 500hp? So it would preferably take a little abuse and not take a s*&t on me? Would this help at all http://www.bankspower.com/products/show/178/9
These are just the beginning, thanks for your time!
