FREE! 4 14" aluminum rims with tires in MASS
TireIron
15+ Year Member
Solid Axle Swap
Methuen, MA
Gone!
I have the 4 original 14" aluminum rims from my 94 ranger with 27x9.5x14 BFG a/ts on them for free along with the matching steel spare. The tires hold air and have a little tread left but might not make it through inspection. All the rims are solid and straight although they have some corrosion on them. The one pictured may be the worst of them, but I havent really compared.
Best part is they're FREE, just come get em in MASS.
I'll take 'em off your hands, and i'd love to check out your setup as well.
I'm in lowell mon-thurs, lmk a time that works for you.
if you still have these rims please lmk I just need to use a set to try to get my truck inspected. thanks :)
I can't guarantee the tread will pass inspection... it's down to the wear bars on at least 1 of them. MAranger needs to get back to me on if he actually wants them, but if he does maybe you can use them first if you think the tread will get you past. My truck is out of commission right now so unfortunately you would have to come out here to methuen to pick them up if he doesn't want them or wants to get them after you use them.
i assume these are gone but i figured id ask anyway. still got 'em?
oops, yea they went to sexybluelady to help with inspection. If she gets done with them she may look to get rid of them afterwards though.
ok thanks. I was just looking for some more aggressive or snow tires for winter. figured if these were too worn id get snow tires mounted on the rims. oh well the search goes on
