94 drive shaft ujoint and 99 slip yolk ujoint different sizes-used napa joint #353. 94 uses speedo cable,99 trans uses electric speedo but 99 trans appears to have speedo drive cast into tailhousing but not fully machined. Does the 99 output shaft have the speedo drive on it? My 94 tailhousing is split from slip yolk freezing to output shaft.
