- Dec 19, 2011
- Shaver Lake, CA
- Automatic
so here is my solution to a common problem, my 33" tires wouldnt fit under the factory wheel wells so i decided to make em 3 inches taller and 3 inches longer while still maintaining the stock look.
so first i cut the fenders out in big squares with plenty of extra to trim if i wanted a bigger opening, then i cut the piece in half and mounted it where i wanted it on the fender using butt weld clamps. i dont know if you have ever used butt weld clamps before but they are a life saver when it comes to this type of welding!
then i started stitch welding it back together, i used a MIG welder on this side but once i start on the drivers side im gonna try to TIG it
here are a few pictures of the fender after all the welds, you can see the patches i had to make
and yesterday i finished all the grinding on the welds
so today im doing a little bondo and primer then on to the other side, so hopefully ill have pics tonight! if anyone has any questions or suggestions feel free to post em!
