Extended Radius Arms
guzzirider
15+ Year Member
Las Vegas
Can you install the Skyjacker extended radius arms on a truck that has the Skyjacker leveling springs? :icon_welder:
i would say no because they show them for 4-6inch lifts. duff has them for i think 2 1/2in lifts IIRC. call them and see what they can do for you
you could, but the camber would be way off....
l8r, John
I'm not exctly sure if you can or cannot, but I see no reason why anybody should.
And it would be sort of a waste as the leveling coils wouldn't really allow the arms to work to their full potential. Not enough travel out of the leveling coils to make it worth your while.
The camber would be off???
I'm not clear on it either :icon_confused:
Maybe because Skyjacker's arms mount farther back down the frame rail and at a lower elevation compared to the stock mounts, coupled with the relatively short leveling coils wouldn't allow the arms to sit where they would normally be with a 4" lift.
Thinking he meant caster....
