- Dec 7, 2009
- Age
- 42
- Automatic
Just wondering if anyone knows which year/model the BW-1354 came in. The wreckers can't seem to figure it out
Just wondering if anyone knows which year/model the BW-1354 came in. The wreckers can't seem to figure it out![]()
The '01 sport had a manual t-case?
Ok...I just found a 1350 out of a late 80's ranger. The wrecker is willing to go $250 for it. Would that still bolt up to a 5r55e? If not, is there an adapter plate available?
wow that seems steep for the 1350! what are you putting this into? cuz if your putting it into your explorer, your going to need the old style front driveshaft to make it work.
yours has a cv joint with a bulb style yoke at the tcase
the older tcases like that and the early to mid 90's rangers have a double cardan joint
Yeah...I figured as much. I should probably go out 'n measure that shaft![]()
Yeah I get what you're saying...would the old style shaft be the same length as the one I have? If not, I'll need to measure it for fitment. That's what I was getting at.
is the 1350 as strong as the 1354, i'm looking for a manual shift one and i can't find the 54m anywhere... i have both driveshafts b/c i did the swap on my b2 and used the 54 but i still have the 50, but they both are electric
Ok then...let me throw this in the conversation. How much abuse can a 1350 stand up to before I have to bury it? What size tire is recommended? I'm not going overly big on tires for a while though...keeping them stock size 'till I get my 4" lift
