Jeff673
I had the accumulator/dryer changed due to a leak. The compresser was working ok for a few minutes then started cycling at low idle. At a high idle the comp stayed on and worked normally. I put a new WOT A/c relay in and it worked for about an hour while I drove home. When I got home, it started cycling again at low idle but works fine if I rev it up a little. I seem to think that maybe something is causing the Relay to overheat, or there is another sensor somewhere. Any help?
