- Sep 13, 2020
- Texas
- 4.0 V6
- Automatic
- Total Lift
- Leveled out +1 inch at the front
- Tire Size
- 33 x 12.5 x R15 Baja Boss MT
- My credo
- For every door that closes another one opens for you to lead others always when you least expect it!
Hi guys, I have a repeatable issue with starting. When this 2007 4.0L sits in the sun, sometimes the engine won't fire up. Cranks fine. Sometimes it tries to kick over slightly. If I keep the ignition in the "run" position in preparation for the second attempt, it seems to help it start. In prior second attempts in starting, still doesn't want to start, one has to hold the key in the run position for a couple of seconds. Q: Is this a fuel pressure switch of something? I'll look for codes, but never saw any before. The motor has a new set of plugs, coils, wires. Still the warm starting issue persists. So I guess it's time to start getting into the fuel system. I have read about some sort of known issue with a "fuel pressure switch"?
--EDIT; The coolant temp sensor possibly, will have to pull the manifold to replace. Will be a project for the very near future.
Thanks for everyone's' input. - Doug
