durfey
wont idle in cold weather
i got a 98 ranger with a 4.0 ohv engine and the check engine light has been on for about a year and a half. it keeps throwing the same code, the fuel system is too lean in banks 1 and 2. I've had my mechanic clean the MAF and both O2 sensors and that didnt work. It has a new MAF sensor and new O2 sensors, new plugs and wires, has been checked for vacuum leaks thoroughly and the vacuum system is plugged off before the vacuum hub solenoid and has been replaced with manual hubs. It runs perfect all summer long but in the canadian winter when it goes below -20 degrees celcius it will idle fine as its warming up but once its at operating temperature it idles like crap and if i leave it idle for too long without feathering the gas at a red light it dies.
Me and my mechanic are both out of ideas other than the ecu? any ideas could be helpful as i may of overlooked something. If i cant find the problem i'll have to sell it this summer when its runnin good.
