alzeng95
Hey all. Newbie to the forum here; second time Ranger owner and still pretty green to working on vehicles. In search of some other thoughts before having to seek shop help.
My current is a 2004 3.0 L that had an engine swap, with about 5k miles on it now. I got her at the end of spring, and on cold and/or wet mornings, was noticing this slight squealing/squeaking as she was getting warmed up. Usually went away by the time I hit my first stoplight. You can hear the “original squeal” in the first clip.
Well now that it’s coming into fall I decided to do something about it, and at the instruction of my buddy who did the engine swap, I started with a little belt ease on the serp belt. Well that made the sound a hell of a lot worse. I took the belt off, both the idler and tensioner pulleys were worn so I replaced those. All others sounded and looked fine so I wiped them and the belt down real good, to no avail. Now it doesn't matter, cold or warm, driving or idling, the worse sound is there. The second clip is the sound now. To me it sounds like it’s coming from the AC compressor. But I am starting to get beyond my knowledge set. Any help is appreciated much.
Original Squeal
New Squeal
Original Squeal
New Squeal
