Window track issues
8cylRWD
Got a 94 Ranger, driver's side window wants to get cocked in the track about 1-1/2" from all the way up. Window tilts out at he top rear, front tilts down a little and it wont got all the way up. Started doing that this spring when driving on the highway in a head wind, seems to push it out when trying to close it. It finally stripped the last 3 or 4 teeth off the regulator, but you can push the window the rest of the way up, and pull it downt he first 1-1/2" by hand. Tracks appear to be ok, all 4 regulator retaining reivet are tight.
Anybody else has something like this? Thanks
check the plastic clips that hold the window to the track. also there is a bolt that hold the track on the front side of the window by the mirror that may have loosend or the tab has cracked and or broken off.
