will this shaft fit a 94 4.0 5spd 4x4 long cab?
Andy D
Marshfield MA
to prevent Found On the Road Dead, Fix Or Repair Daily
Bought for 2000 FORD RANGER but fits other years. 4x4 - 5 SPEED STICK SHIFT - DRIVE SHAFT- NEVER USED- 126" - BOUGHT NEW WITH NEW U JOINTS . Install complete instead of replacing u-joints. $75.00
TIA
One issue you would have with this shaft is that the companion flange on a 1994 is the small one
2000 SHOULD also be the small flange at the T-case end, but MAY be the larger diameter flange.
The larger diameter flange is the same diameter as the flange on the rear axle.
If you an deal with the potential of replacing that flange adapter the shaft will either fit OR you can make it fit
If the driveshaft does have the "large" front shaft and you need the small one give me a shout, I have one of the proper small ones sitting on the window sill in my workshop
I've already converted my truck to the larger flange.
