Ok, today I went ahead and replaced the IAC valve, the PCV and the ACTS...in that order, checking after changing each one to see if there were improvements.
I also sprayed starting fluid on and around the intake and all vacuum lines checking for leaks and there were no leaks... really surprised me to say the least! lol
After the IAC valve, with the MAF sensor plugged in, the truck would idle and revved up with some finesse of the accelerator pedal without dying... so that's an improvement.
After the PVC valve, it ran somewhat smoother, but still not a complete fix.
After the ACTS, no improvements.
So, for an update, the truck will run with hesitation and spits and sputters and has a really bad odor from the exhaust now with the MAF plugged in...
Unplug the MAF and it will literally melt the tires off the truck if you get on it, but still has some hesitation in the acceleration.
It will bug the crap out of me to just drive it with it unplugged, for my sanity I can't stop this journey until the MAF is plugged in and the truck performs as it should...
Any thoughts or help planning my next step will be greatly appreciated.
