Who has broken a Dana 35?
i am impressed that junkie doesnt kill steering parts and boxes ect. very good driving. but i just like idiot lines some times just for the what if factor.
I've killed a couple steering links :secret: , although it's mostly been the result of smacking it on rocks. No boxes though (at least not as a result of offroad use).
rbv do not have 1330 factory.
'98up uses 1330 joints.
So do I have 1310's stock right now? Im lost.
You said you had a replacement u-joint shaft. No way for any one of us to know what you have since it's not stock (1310 is simply the most probable). Post a pic of it.
D35 uses a 1310 joint (aka Spicer 5-153X). 5-760X is the D35 front axleshaft joint.
Only problem I've had is my used lock rite is getting worn out and is starting to unload when the driver's side front is the only tire gripping...
