swynx
was messing around with the pickup today, i need to cut the fenders more. was going to mark some lines, when.... i pulled out the tape measure and realized that for some reason the passenger tire is 3.5 inches from the fender mount, and the driver side is 4.5 inches. so the tire rubs the mount slightly on the passenger side and not even close on the drivers side. measured from the center of the beam, right behind the u joint on both sides, back to the radius arm mount, got 31" on both sides. it doesnt wander, or track funny down the road. i dont notice that any thing is bent. it does have a home brew alignment on it which seems to work good, i have pretty good centering of the wheel. but the caster is not perfect.
so where should i measure from? place a plumb bob on the front frame horns and just start measuring?
