When do I change the timing chain?
if you want the chain/tensioner/guide to last. keep the oil clean.
i've replaced many broken chains and worn guides from lack of oil changes... also usually have to replace bent valves
Good to know....I've noticed a lot of manufactures switching back to chains. Now that's one less thing I need to worry about!
Okay, a newbie question. I have a 2010 Ranger SuperCab - 2.3 L four.
Do I have a Duratec? (and a chain?)
when the timing chain slips or breaks it's normally time for a rebuild anyway.
My other truck is a 96 F150 supercab with a straight 6 and it has 310,000 miles on it.........still has original timing chain but has had 2 transmissions and 3 rear main oil seals so far.
good luck busting that chain on the ol girl:D
