Hardwareman
I just looked under my Ranger and saw a spot of oil under it. I just replaced all the gaskets and seals and thought the oil leaks were over.
It's coming from the front of the engine on the drivers side right above the oil pan. Right after I completed all the seals and gaskets I immediately had the "brand new" front main leaking so I replaced that and it stopped. Now this?! I'm thinking the oil pump?
The only thing I can think of is the oil pump. Maybe I can pull the oil pump and apply some black RTV to the copper gasket that bolts it to the block? Does anyone know if there's a problem with the 2.3 leaking right there because I had this same leak before along with all the others?
Man, I don't really want to deal with this right now but I guess I have to.
Allen
Allen
