wat transmission 4 a tcase
PaleBlue90
Boosted (Not Stock)
Aurora Colorado
i got a 90 ranger 2wd, can i bolt a tcase up to this transmission? if so wat needs 2 b done? i want 2 bolt up a manual lever t case
well, you will need to change the output shaft and tail housing
ok thanx so just get the output shaft and tail houseing from a 4wd ranger with this transmission?
yes, but make sure that the transfer case will bolt to the transmision as well. What exactly are you trying to accomplish?
If you do that you might as well use that transmission instead of wasting time turning your 2wd tranny into a 4wd tranny.
You could also mount up a divorced transfer case, but I'd go with what they said. Just find another tranny and transfer case and swap em.
ive been thinking and i think im gonna do that
