- Aug 6, 2007
- Age
- 48
- Berrien Springs, MI
- My credo
- If you can't go through it or around it, then go over it.
to my chevy pick up. Whats the rule of thumb on power gain? 1 hp per 10* lower air charge temp?
as you can see there is not enough room to add plumbing for an intercooler here
I either need to reclock this 180* (upper plenum)
or reclock the turbo
which would be the better way to go. If I reclock the plenum it can only go 180* and then the air tube would cover the fuel filter meaning I would have to take it off every time I had to change the fuel filter. no telling what problems I would run into by reclocking the turbo.
then I run into the problem of not having enough room to mount the intercooler anywhere. there is not enough room infront of the radiator because of the over sized radiator, over sized trans cooler, oil cooler, and A/C what ever part is infront of the radiator.
Normally I think hood scoops are gay (because of the obscene amount of mall crawlers around here with non functioning hood scoops. Hodd scoops are fine if they are functional) but I was thinking of mouting the intercooler on top of the plenum with a heat shield and cutting a hole in the hood for the air flow and covering it with a scoop.
any other ideas?
any other ideas?
