aknott1994
- Feb 17, 2020
- Michigan
- 3.0 V6
- Automatic
My speedometer is having some issues I have never seen before. When I got the truck the speedometer didn't work so I replaced the sensor on the T case and it would bounce a little and that is it. I pulled the gear and it was worn pretty bad in the center so I replace it with one I had on hand(admittedly probably the wrong tooth count) and it works somewhat. It bounces up to 35 then smoothes out but it is progressively more off the faster I go. I thought putting the correct gear on would fix the problem but I am not sure with the issue. Up to 35 it is 5mph off, from 35-50 it is 10mph off, and when it reads 55 I am going 70mph. Why is it varying so much?
