Wheelwright
A 2011 wouldn't have been my first choice for a recipient, but a patch of black ice turned my '08 into scrap, and I had to have something on very short notice. It's much harder than I expected to find a 5s, 4wd, supercab, with a limited slip axle, and a really clean '11 was where I found it. Is/is.
I've read around, both in this forum and in the tech pages, trying to minimize the stupid questions. I'm sure I'll have more, but initially, I got them down to three (maybe four).
How much of a monstrosity is the wiring going to be? I think (hope) that the traditional explorer/mountaineer long block and engine harness will have at least the same layout and connectors. I know that the harness will be very different inside those connectors, but mechanical compatibility is a good place to start.
As well, I know there is a donor vehicle whose harness allows the use of a 5-speed. I found it, and can't find it again. Idiot me.
Is there any (sane) way on God's green asphalt to put a transfer case on a robust T-5, and have everything more or less in the right places? I know it's been done, but it seems to involve some pretty exotic parts, custom this'n that, and new holes in the transmission tunnel.
I know that the trans/transfer from a 97-03 v6 f-150 will bolt right up, and even use the same transmission mounts. All a good thing, and the M5OD-r2 is certainly worthy, but two things about it I don't like. First it's a truck trans, and it shifts like a truck trans. That's just me whining, but the other trouble is that my intentions for the engine are pretty close to what the R2 will handle, and liquefying a transmission just isn't on my bucket list.
Does anyone have an accurate weight for the sohc v6? I want to get some idea how much weight gain I'm looking at, and what I might have to do to improve the F/R balance. Aluminum heads might be sensible just for the weight savings. I've seen several Ford engine weight tables, but they all seem to ignore the OHC Cologne engines.
IIRC, a 351 will actually fit under the hood. Tight, but doable. Will the harness from an explorer/mountaineer run that engine? That's probably a REALLY stupid question, but if reprogramming for the larger engine is all it will take, that's golden.
Wheelwright
Wheelwright
