adsm08
Senior Master Grease Monkey
Ford Technician
- Sep 20, 2009
- Dillsburg PA
- 4.0 V6
- Tire Size
- 31X10.50X15
I am working on a 2011 Chrysler Town and Country, and I need the diagram showing the wire colors involved in the fuel pump relay and pump itself, if it even exists.
This is information that Chrysler seems to have not bothered to write down, let alone issue in any sort of publication, as I cannot find it anywhere.
If anyone has access to AllData, or a similar service, particularly over the weekend, and could post the info that would be super helpful.
I am trying to bypass a failed fuel pump relay in the TIPM, and cannot find the wire functions. This van belongs to a single mother of 4 who is currently borrowing one of our cars while I work on this since it is her only vehicle.
Even is someone has installed the bypass kit Chrysler has and happens to know which wire is the one the PCM uses to ground the relay, that would be enough. I can work around all the rest of the factory wiring.
