Hey all two questions
1. I have a set of 2005 Dodge Ram 1500 Aluminum 17 x 8/9 rims with a 5 x 5.5 bolt pattern. I can get a the EcoPath 285/70/17 AT tire for around $100 each at Walmart. Trying to save some $$
The rangers have a 5 x 4.5 bolt pattern. There are adapters (not spacers) out there that you can "Up-size" to a 5 x 5.5 bolt pattern?
It will push the wheel out about 1 to 1.5 inches, is that too much. Has anyone done this "Up-Size" adapter switch and what are the Pros/cons of doing this?
AND
2. What is the largest wheel tire combo I can put on my 2 WD with a 4 inch lift 2003 Ranger Edge. Can I up size to the 17 x 8/9 inch wheel?
AND
