renton
- Oct 17, 2015
- Automatic
My 05 Ranger with 3.0 has had good compression results in all cylinders except #2 which is lower at 120psi. Rest are around 150 or 160. It's been this way since I got the truck 6 years ago and haven't gotten worse. Vacuum gauge reads normal and no codes. If this was burned exhaust valve wouldn't my vacuum gauge flicker up and down? It also hasn't gotten worse in 6 years which seems odd for valve. I'm leaning towards worn rings in there causing slightly lower compression. What do you think. It's ok except my idle is always rough.
